Carlson Survey 2021
5 Users
MITCHMAN79K
(@mitchman79k)
We have a spectra precision Ranger 3 Data Collector. Is there a method that does not require the use of Survey Pro to allow our field crew to have the fld codes that the office uses?
Posted : January 6, 2021 10:48 am
JerryS
(@jerrys)
Not certain what you are asking, but I interpret it to be have the same codes in the Ranger that you use in the office.?ÿ That once was as easy as editing a text file.?ÿ I think now you need a utility function in Spectra Precision Survey Office because the code file in current versions of Survey Pro is no longer a text file, at least the extension is different.
Posted : January 7, 2021 8:58 am
jph
 jph
(@jph)
How complicated are they??ÿ Can't you print up a list and they can just punch them in as they go??ÿ
I've never used pre-loaded field codes - find it fairly easy to type, EP, EG, WG, etc
Is that what you're asking?
Posted : January 7, 2021 9:11 am
Bob Westerman
(@bobwesterman)
What software is on the Ranger?
Posted : January 7, 2021 8:34 pm
PNEZD comma delimited.
D is the key for F2F.
Posted : January 8, 2021 10:37 am
