Trimble R10 Base Fi...
Trimble R10 Base File Date Problem
2 Users
Skeeter1996
(@skeeter1996)
Just got a new R10 setup. The Base files show on the unit with a date of June 5, 1980. If I convert them to RINEX they run through OPUS no problem, but TBC fails to upload the file.
Do I have to reset the date somewhere?
Posted : June 5, 2017 4:49 pm
stlsurveyor
(@stlsurveyor)
Skeeter1996, post: 431162, member: 9224 wrote: Just got a new R10 setup. The Base files show on the unit with a date of June 5, 1980. If I convert them to RINEX they run through OPUS no problem, but TBC fails to upload the file.
You can check the status and all settings of the R10 with your smart phone or laptop by connecting through the WiFI the r10 broadcasts.
If necessary you should be able to make all your adjustments.
Page 34...
https://www.neigps.com/wp-content/uploads/2014/01/R10-UserGuide.pdf
N10,000, E7,000, Z100.00
PLS - IL, MO, AR, KS, MN, KY
Posted : June 5, 2017 7:24 pm
