Roll-your-own NTrip...
Roll-your-own NTrip server-Success!
A portable base station accessible over the internet-I have been wanting to get this setup for years, finally did it.
I have an R10 with a built in NTrip server, but after it was stolen in August, I decided I needed to do things differently.
I bought a used R7 (GPS+Glonass) this summer.
I recently purchased a microhard Bullet Plus modem: http://www.microhardcorp.com/BulletPlus.php - $399
The other two items I needed to make this work were software:
TCP-Com: http://www.taltech.com/tcpcom ($199)
SNIP: simple NTRIP caster: http://www.use-SNIP.com&apos ;">www.use-SNIP.com (Lite version, free)
1) the serial port on the modem is configured to be a server, and assigned a port number. A Rule is created on the modem to accept connections over the cell link and allow the port number access. Also, port forwarding is setup to pass the port through the modem to the serial port
2) On my PC at the office, a virtual serial port is setup on TCP-Com to connect to the IP address of the modem using port number assigned in step 1.
3) SNIP is configured to connect to the com port from step 3 (serial stream), and to setup a caster at the IP address of the computer in the office, port 2101. This is username and password protected (i.e. only able to connect with username/password)
4) connect the modem to the R7 (port 3) with a null modem cable. Took me a while to figure out that I needed that type of cable. I put a null modem adapter and a gender changer at the end of a standard trimble cable with lemo on one end and DB9 at the other end
5) Using my laptop I can connect to the R7, and with GPS Configurator set a reference position (type in coordinates or use HERE), and tell it to stream RTCM 3.0 out the port. Also using my laptop I can connect to my desktop and start the NTrip caster.
6) I had to open up a port forwarding rule on my router in the office to allow port 2101 through, and direct it to my PC
7) Now I have an NTrip caster running, and can connect using either the name I assigned to my IP address (xxxx.xxxx.com) or the IP address. The number of clients is unlimited, the number of incoming stream is limited to 3 in the Lite version of SNIP. Since I am only running one incoming stream, not a problem. Curiously, the only way to do this is by a serial port connection into SNIP. It will relay from an NTrip server, but the R7 does not have any NTrip capability. Hence the need for TCP-Com. This works great, I can actually run GPS Configurator or DataTransfer over the virtual com port to the cell modem to the receiver.
Alternatively, the provider of SNIP offers a free (for now, they say there may be a small annual fee in the future) Ntrip caster that I can stream the data from SNIP to so that the connection does not have to go to my PC. But, I don't like that idea, as anyone can see my mountpoint, and could decode the data and see where my receiver is.
With the R7 I can put the receiver and modem in a locked box, chain it to a fence or pole, and be a little more secure than having the R10 out in the open. Plus, if the R7 is stolen, it is much less expensive to replace. This will also work with R8's, 5700 (no Glonass), 4700, etc.
Another nice thing about the Bullet Plus modem is that it has wifi built in (similar to a mifi), but also LAN Ports. I can use it as a backup internet access device in the office if my internet connection goes down (it did last year for 1+ days due to a car crashing into a pole), or anywhere else I am at. There are cheaper versions of the modem without wifi and LAN.
Posted : January 26, 2017 9:20 am
This would have been much easier if someone would make a single device that has all of this built in...modem and Ntrip Caster. Of course the R10 has it all built in, but I don't feel comfortable anymore leaving that receiver setup unattended in a lot of places that I work.
Maybe this could be done using a Raspberry PI?
Posted : January 26, 2017 9:56 am
leegreen
(@leegreen)
This is not gonna work with Trimble, but Leica SmartNet looks really interesting. It uses no base and no radio. The corrections all come from SV. The downside is, it takes about 20 minutes to initialize, and the yearly subscription cost $2500. The upside, it works anywhere in the world, so long as you can get SV's, no cell service need.
Also not gonna work with Trimble, but Topcon Magnet Relay does all this for you. You pay a yearly subscription, just $300.
All you need is DC w/ cell modem running Magnet Field software at the both the base and the rover. The takes care of all the IP address, protocols, servers, and casters. The time to setup a Network Relay base is no more than setting up base with UHF radio.
Posted : January 26, 2017 1:14 pm
leegreen, post: 410990, member: 2332 wrote: This is not gonna work with Trimble, but Leica SmartNet looks really interesting. It uses no base and no radio. The corrections all come SV. The downside is, it takes about 20 minutes to initialize, and the yearly subscription cost $2500. The upside, it works anywhere in the world, so longs as you can get SV's, no cell service need.
Actually, the Leica service sounds just like the Trimble RTX, which the R10 does (for a subscription, around $3000), and it works anywhere in the world (satellite broadcast). I had a large project in northern Canada that paid for the subscription in just that one job. Yes, it takes about 20 minutes or so to init, but there was no other way to do it up there and the distances were large.
The topcon service sounds like a useful thing, I see no reason why some enterprising person or company couldn't offer a similar service not tied to any particular manufacturer. I should add that to get all of the above to work correctly I had to switch to RTCM (3.0) from CMR+. I see no down side at all, in fact some research I did online says that RTCM 3.0 has smaller data packets than CMR+. I think the resolution of RTCM 3.0 is 0.5 mm, whereas CMR+ might be a bit higher resolution, but that is well under the noise level of RTK
Posted : January 26, 2017 1:20 pm
shelby-h-griggs-pls
(@shelby-h-griggs-pls)
John, very cool, I guess I took the easy route, my Intuicom Bridge-X (make that plural units now) have this functionality all built in, albeit at a higher price tag. Of course I also got the 900 Mhz radio too for close in work. Being able to host your own base station anyplace you have cell signal at base and rover is very useful and is something I do quite often when outside a RTN or where I want the utmost control over the data. My next experiment is going to be seeing if I can hook an Inmarsat satellite terminal to the bridge for RTN corrections in areas of RTN coverage BUT no cell service. I think I only need a WiFi -> Ethernet adaptor to try this.
SHG
Posted : January 30, 2017 1:19 pm
I only have the older bridge. So the newer model has a built in NTRIP server/caster?
Posted : January 30, 2017 2:09 pm
I found https://www.pinterest.com/pin/555139091554294193/&apos ;">THIS out on the intranets...
Looks like it could be useful...
Posted : January 30, 2017 2:57 pm
gschrock, post: 411584, member: 556 wrote: I'm trying to find that out... I have an old one which works great but wanted to see about a caster capabilities.
I did find one other solution that uses only one external device, but does not allow authentication (or at least I have not figured that part out yet).
By pushing corrections from the base into the serial port of a Sierra GX440 or RV50 (with a static IP) the rover connects directly to a forwarded port (no NTRIP involved). Have to been able to get multiple ports forwarded to work, but working on that.
A variation with two devices is a device server connected to the modem and forward ports from the static IP. Again, no authentication.
Found some services (for Ag users) that will host on their caster for you 9/then only a modem is needed) but cheapest was about 50 a month.
Gavin: I can not get the "non NTrip" solution you mention to work. I have to push the corrections out the serial port to the modem to SNIP running on my PC, which then functions as an NTrip caster. Maybe I am not configuring the rover correctly to connect directly to the serial port at the base via the modem. It connects but does not see any data stream that it recognizes.
Posted : January 30, 2017 3:04 pm
shelby-h-griggs-pls
John Hamilton, post: 411575, member: 640 wrote: I only have the older bridge. So the newer model has a built in NTRIP server/caster?
Yes, Intuicom calls it http://www.intuicom.com/images/casestudies/BridgeX_SURVEY_solutions.pdf&apos ;">base/socket mode (see page 2) which allows four devices to log into the IP of a single bridge. I am trying to figure out how to set my second Bridge up to log into the first and rebroadcast on 900 Mhz (diagram at bottom of page 2)
So far I have successfully set up a base with the bridge connected and access it with my rover modem or even my phone to check the status of the bridge remotely, just got the 2nd bridge this month for two reasons; 1) to do what I outlined and 2) the new https://www.intuicom.com/images/datasheets/4G_RTK_Bridge-X_Datasheet-RS_9Nov2016.pdf&apos ;">4GLTE model has Band 17 in the 700 Mhz spectrum, that is where a lot of new cell service is being deployed, thus usable a lot more places and bonus is it is 4GLTE not that you need the speed for RTK data, BUT I have used the bridge hotspot to access e-mail when my phone showed no service, granted it can't make signals from nothing, BUT definitely can pull in cell service where a handset fails.
SHG
Posted : January 31, 2017 1:54 am
That looks like a big improvement. I just wish Intuicom had a better upgrade path, they do not offer much of anything for a trade-in. I realize they have development costs, but I wish their units were more modular so that boards could be swapped out when new features become available. I will probably get the new model sometime, but I would not trade in my old model, as it is worth more to me than what they offer.
Actually, what I have setup is the functional equivalent of the base-2-socket, except my PC in the office is generating the corrections, and the rovers are connecting to that.
Posted : January 31, 2017 4:28 am
shelby-h-griggs-pls
John Hamilton, post: 411670, member: 640 wrote: but I would not trade in my old model, as it is worth more to me than what they offer.
Exactly and why I have two Bridge's now, it does add some functionality having two, BUT if the upgrade path was sweeter, I might of just opted for a single new one.
SHG
Posted : January 31, 2017 2:35 pm
shelby-h-griggs-pls
John Hamilton, post: 411670, member: 640 wrote: but I wish their units were more modular so that boards could be swapped out when new features become available.
Not just them, there is zero reason Pacific Crest couldn't have offered an upgrade to narrow banding on the PDL's, Leica and Trimble couldn't upgrade the older 2G modems, etc. with just a simple board swap, but instead you have to get rid of gear and buy the newest modem or radio as a complete replacement, really chaps me that it is that way.
SHG
Posted : January 31, 2017 2:39 pm
Lanterino
(@lanterino)
Hi there! I happen to have a license of Serial to Ethernet Connector. Do you think it will do a good job instead of TCP-COM?
Posted : July 14, 2017 8:12 am
Lanterino, post: 436986, member: 12881 wrote: Hi there! I happen to have a license of Serial to Ethernet Connector. Do you think it will do a good job instead of TCP-COM?
I would say yes, nothing special about tcp-com that makes it essential, i just know that it works.
Posted : July 14, 2017 7:16 pm
ngocdinhks
(@ngocdinhks)
Hi Jo
I have 2 trimble r7, TSC2, WIfi + cable connected to PC, + Lefebure Ntrip Caster.
I want to work at a distance. 15 km.
I tried to connect the trimble r7 + PC but it seems Lefebure Ntrip Caster does not work and I have spent quite a bit of time for this.
Anybody have specific instructions for this Ntrip operating system? Or what additional equipment do I need?
Posted : May 21, 2018 10:47 am
