Anyone else confirm this??ÿ Last two days.?ÿ I submitted to ngs yesterday.?ÿ Still cannot select any antenna (seems the related antcal table link is broken).
I??m not having that issue, but I can??t get it to accept any of my files today. ?ÿUsed Trimble centerpoint service as a work around.?ÿ
submitted and received solution about an hour ago.
fast static, used extended solution, may make a difference.
Thanks.?ÿ My NGS advisor up here, on a fed computer and running same v. of Edge, is not experiencing this issue, nor is she having issue in Chrome.?ÿ On both browsers on my fed PC, same issue - see screenshot.?ÿ
just cleared cache in Edge, same inability to pick antenna.
Tried submitting files via Survey Tools (trimbleaccess.com) and no luck. (aborting reply, referencing the same cookie cutter error message.
@ozzy84?ÿ
I simply can't submit any style of submission since i can't pick any antenna from the list.
Is that 2 2 oh or 2 2 zero? Not that I'd expect it to matter unless the actual file was the other one.
@bill93 Hi Bill,
That is upper case Zed 0.?ÿ I've tried only Trimble T02 files, converted to Rinex, and to remove any chance this is rinex, I've loaded NETR9, R8 Model 3, R10, R10-2 files (converted over the course of 8 years) into Chrome, https://geodesy.noaa.gov/OPUS/ and Edge OPUS: the Online Positioning User Service, process your GNSS data in the National Spatial Reference System (noaa.gov) on two different Windows 10 computers, both of worked previously.?ÿ Another person in my group can't get antenna's exposed either.?ÿ Same files that loaded into opus fine, so its not the file type, nor version of rinex converter i am using or have used.?ÿ?ÿ
Strange, this is a new one for me.?ÿ I cleared cache again.
Any FEDS out there, DOI if possible that are seeing this??ÿ ?ÿTrimble's online submission on same files (using T02) are passing.?ÿ
Solved.
This issue was resolved only when on government computers, we jumped off the DOI intranet.?ÿ Tested both hardwired on DOI and on working laptops using VPN (DOI uses Pulse Secure).?ÿ ?ÿWhen disconnected from the DOI subnet, including Pulse Secure, OPUS performed as expected.
Now the real work begins..... Its something in our DOI firewall that prevents OPUS submissions, and strangely, its accessing the table that NGS relates to (the antcal table) which is exposed in a pull-down.
Thanks for this community for testing!
"The world will one day be run by IT support."
-a former supervisor of mine...
You used to work for Cyberdyne Systems?
While it didn't like my file, it did allow me to choose an antenna.
The issue has been solved.?ÿ NGS fixed the issue of accessing the antenna's, no idea how, but its fixed.
This issue was persistant across the DOI (Department of Interior) sphere only when logging in using VPN (pulse secure) or intranet.?ÿ This did not affect USDA.?ÿ Kudos to our NGS Advisor, Nic Kinsman for chasing this down with a ticket.
NGS responded on Friday that they were watching this forum post.?ÿ Gotta love Surveyorconnect community.
Thanks surveyors!
I experienced this recently, I thought it was my slow internet connection (working remotely), but seems to have resolved itself, submitted 20 files yesterday.
SHG
