Greetings all,
I've quite a problem with one 4000 receptor as the calendar list the year 1995, and no amount of hard resetting will make the receptor take the correct date, anyone else had a similar problem? if so what could I do to fix it.
I have the same "problem" with my OLD Novatel Receivers.
I simply open the RINEX file in NOTEPAD:
94 2 18 14 21 40.0000000 0 7 1 17 26 7 8 9 11
122120414.6910 95158791.8670 23238742.180 23238749.109
Use the "replace" function
Change 94 2 18
to 13 10 04
which returns
13 10 04 14 21 40.0000000 0 7 1 17 26 7 8 9 11
Ya have to pay attention to files crossing GPS Midnight, and the process is NOT idiot proof (what is), but it works for me. I also place a "COMMENT" line in the header to record what I did.
edit
Be sure to change the file extension from .94o to .13o
I see, so nothing short of editing the rinex to present the correct date? is that hexadecimal? I tried to convert it to decimal but it doesn't show up as a current date.
Dave RR, post: 323756, member: 10082 wrote: Greetings all,
What firmware version are you using? It sounds like something that predates the week rollover update. Updated firmware is available at the UNAVCO page for the Trimble 4000: http://facility.unavco.org/kb/questions/476/Trimble+4000+Resource+Page
Hmmm...
A RINEX file is a highly formatted ASCII text file (nothing more, nothing less).
The line:
"translates" to:
1994 February 2nd 14h 21m 40.0000000s 0 7birds prn1 prn17 prn26 prn7 prn8 prn9 prn11
prn = Pseudorandom noise, which is the unique identifier assigned to a each [active] "bird" in the constellation at any given time. Different birds will "share" the same prn over time, but never simultaneously.
The line:
Contains the L1 L2 C1 P2 values.
Editing an entire RINEX file should only take a couple of minutes regardless of it's size. Obviously a file crossing GPS midnight will take a minute or so longer.
It all gets back to the GPS rollover a few years ago. You can figure out the shift using various information online, or just KNOW what day you actually collected the data (my preference).
Edit...
Or you could update your firmware as Jim pointed out above.
Of course this will probably NOT solve the problem for files collected BEFORE the firmware update.
I know we had 2 4000 units when the Y2K thing hit the fan and we had to pay Trimble some money at the time.
Please do what Jim suggests and update your firmware. It's a free download. If I recall correctly, it needs to be done from within a Windows XP 32-bit virtual machine.
Also if your receiver hasn't already needed its internal solder tail style batteries replaced, it will soon. It's not difficult. I think UNAVCO has instructions available for that too.
I'll try updating the firmware, thanks all.
