virtual serial port with HP 48 data collector using TDS
HP48 data collector user
(@hp48-data-collector-user)
It's time to get a new computer. I've been transferring my collected data using a computer running on XP with a 9 pin serial port. I'm told 9 pin serial ports will not be found in a new computer. Has anyone made the leap to Windows 7 with a virtual serial port? Any other method found to work?
Regards,
Paul
Posted : May 22, 2014 7:43 pm
stephen-ward
(@stephen-ward)
It's true that you won't find them stock on new machines. You can always add a serial port card to the machine you buy or just order it from Dell or similar with one already installed.
Posted : May 22, 2014 7:59 pm
mattsib79
(@mattsib79)
I have a serial to USB adapter to download my HP to my windows 7 and windows 8 machines. I have never had a problem with it. After the driver is installed it is recognized as com 2.
Matt
Posted : May 23, 2014 5:35 am
Thanks Matt,
That's very encouraging. Do you recall which virtual serial port you downloaded?
Regards,
Paul
Posted : May 23, 2014 11:11 am
