TSC2 & AT&T Mobile Hot Spot
teffinger
(@teffinger)
Does anybody know of an AT&T mobile WIFI product that can be configured to work with a TSC2? I got a ZTE Velocity but I can't get it configured correctly to work with my TSC2.
Thanks,
Tom
Posted : September 4, 2015 12:19 pm
exbert
(@exbert)
Make sure to turn off the hotspot's encryption and make it an open network (no password). The TSC2 doesn't work with the encryption.
Posted : September 4, 2015 1:47 pm
If you go with open (no encryption), you can still setup mac filtering with many hotspots. You enter the mac address of your TSC2 into a list as an allowed device. That means that no one else can connect, but they can "see" your data (who cares?).
I was working in a large eastern city last year, using a TSC2 and my phone with no encryption. When i would stop to survey a point I would sometimes see devices connecting to my phone. After i setup the mac filtering it was no longer a problem.
Posted : September 5, 2015 5:56 am
joabmc
(@joabmc)
I'll have to look at my setup. We use an AT&T hotspot with our TSC2. I remember having to play with it for awhile to work the kinks out but eventually got everything to connect. The newer hotspot has a touchscreen display which I find useful. I'm now able to track when it's a service issue causing problems as the screen will show level of service available. Just another way to troubleshoot.
But to answer your question, yes it can be done.
Posted : September 5, 2015 7:46 am
teffinger
(@teffinger)
The one I got was only $0.99 and I don't think it has the required settings for the TSC2. I tried using open (no encryption), but it still wouldn't connect. I decided to try a Novatel MIFI because I heard that they can be configured correctly. Joabmc, if you have the time, please post your setup info.
Thanks,
Tom
Posted : September 5, 2015 7:58 am
joabmc
(@joabmc)
I snapped a few shots of the device and current settings
And yes the hotspot encryption is all turned off. Like someone else mentioned, it is open for any user to connect but I really don't care. I really only use it for our GPS to connect to our network.
Posted : September 6, 2015 11:29 am
