Trimble 4000 data logging not installed
5 Users
Scene
(@scene)
I updated the firmware after REMOTE MONITOR ACTIVE message to 7.32. Now it says RTK only and data logging not available. I have other trimble 4000 and none of them has this issue. Anybody encountered this problem? Any solutions?
Posted : October 23, 2016 8:27 am
Did this receiver have data logging enabled prior to the firmware reinstall? Data logging was an option, and not all 4000SSi units were sold with it enabled.
Posted : October 23, 2016 8:55 am
Scene
(@scene)
I bought it some weeks ago and it came with the message REMOTR MONITOR ACTIVE, so i don't know. The model is 4000DS.
Posted : October 23, 2016 9:00 am
I don't know much about the DS. I believe it's a single-frequency unit.
Posted : October 23, 2016 9:32 am
Dane Mince
(@danemince)
you need to replace the internal batteries and this will fix the active monitor issue. You may need to log data to an external device.
Posted : October 23, 2016 11:21 am
Scene
(@scene)
Yes i did replace the batteries and installed firmware. I think Jim i right and there isn't an option for data loging at all.
Posted : October 23, 2016 3:09 pm
Dane Mince
(@danemince)
You need additional ram installed to log data,this is something that you can check for when you power on the unit
Posted : October 23, 2016 7:21 pm
My understanding of the 4000SSi model is that they all come with 256K installed, but that logging access to that RAM (and any additional RAM) has to be authorized by the factory or an authorized dealer. I assume there's some special software required to accomplish this. I know that in 2001 I paid $500 to get logging authorized along with a small RAM upgrade.
Posted : October 23, 2016 8:04 pm
If it doesn't have logging enabled now, I would think it nearly impossible to get it enabled as they no longer support that model.
Posted : October 24, 2016 5:30 am
Scene
(@scene)
A friend of mine suggested that it may be possible to connect TDC and log data to it. What do you think, will it be possible?
Posted : October 25, 2016 12:12 am
in-the-sandpit
(@in-the-sandpit)
Scene, post: 396768, member: 12220 wrote: A friend of mine suggested that it may be possible to connect TDC and log data to it. What do you think, will it be possible?
Realistically about your only option. TDC or TSC1 with the survey style configured to log to the controller. As John Hamilton points out, you won't be able to to purchase the option from Trimble any longer.
Sent from my SM-G935F using Tapatalk
Posted : October 25, 2016 2:23 am
