Tools I wish I had
12 Users
Total station, that goes on prism pole. Weighs less than 3 lbs, and is reflectorless.
An assortment of shot filled hammers. Dead blow, hollow, 2# 3# 4# 6# 8#
Subsurface radar, to find stones, and non ferrous monuments.
Cordless jackhammer, with hammer, hammer twist, and twist. One with scads of power, drives rebar, hubs, or monuments.
Metal detector, that has 12" screen, and surface penetrating radar, so you can search real time.
Posted : September 5, 2017 12:09 pm
makerofmaps
(@makerofmaps)
How about a drone that can shoot hubs? Then you don't even have to get out of the truck to do construction layout. Once N. Korea drops the emp life will be good again. Pulling a chain, log tables, hand drafting, no internet.
Posted : September 5, 2017 12:34 pm
Posted : September 5, 2017 12:51 pm
[MEDIA=youtube]OVfhTqL95jY[/MEDIA]
For clearing sight lines. I know, I know, if only I had a Javad.
Posted : September 5, 2017 12:59 pm
Nate The Surveyor, post: 445184, member: 291 wrote: Total station, that goes on prism pole. Weighs less than 3 lbs, and is reflectorless.
yes, I have the same wish, a lightweight total station that can be easily packed with a carbon fiber tripod. The tripod should collapse to 2' or less long and be able to accept a peanut type prism.
Posted : September 5, 2017 1:00 pm
Dave Karoly, post: 445206, member: 94 wrote: yes, I have the same wish, a lightweight total station that can be easily packed with a carbon fiber tripod. The tripod should collapse to 2' or less long and be able to accept a peanut type prism.
Sounds like you need a Kern Mountain Total Station
Posted : September 5, 2017 1:07 pm
James Fleming, post: 445208, member: 136 wrote: Sounds like you need a Kern Mountain Total Station
Our average age is getting older but the mountains aren't getting flatter. On this last project we had the kid (31) to haul the S7 and one tripod but there was one week when it was just two of us geezers. Sure would be nice to have a very lightweight setup.
Posted : September 5, 2017 1:09 pm
Back in the day (early 70s) we had a Kern DKM-1 w/ aluminum tripod. It was about as light as anyone could want, but the EDM (stadia) was a little iffy.
It didn't need any batteries though, that was a real +
Posted : September 5, 2017 1:11 pm
Loyal, post: 445212, member: 228 wrote: Back in the day (early 70s) we had a Kern DKM-1 w/ aluminum tripod. It was about as light as anyone could want, but the EDM (stadia) was a little iffy.
Kern DKM-1 + Disto + Duct Tape
Posted : September 5, 2017 1:14 pm
[USER=136]@James Fleming[/USER]
May red green knock on your door! 🙂
Posted : September 5, 2017 1:56 pm
gmpls
(@gmpls)
I believe there was an article in POB or American Surveyor several years back that showed a Nikon Nivo being used on a prism pole with bipod. I can find it though.
Gregg
Posted : September 5, 2017 2:19 pm
shawn-billings
(@shawn-billings)
GMPLS, post: 445221, member: 8404 wrote: I believe there was an article in POB or American Surveyor several years back that showed a Nikon Nivo being used on a prism pole with bipod. I can find it though.
Gregg
It's cool that you remembered that Gregg. At the time I was hoping it might spur a viable concept amongst the manufacturers of total stations. Seemed like a viable idea.
http://www.amerisurv.com/PDF/TheAmericanSurveyor_Billings-NikonNivoC_Vol7No8.pdf
The Nivo was a good prototype because it had the data collector built-in. This is crucial in my opinion for a truly lightweight, compact, pole mounted total station.
Posted : September 5, 2017 2:48 pm
An IMU (inertial measuring unit) that was affordable, light enough to hand carry, and survey grade accurate. No satellites, no lines of sight.
Posted : September 5, 2017 3:53 pm
spledeus
(@spledeus)
Bruce Carlson had a beta of the total station on a stick in 2011 at the ALTA ACSM survey summit. It had wireless to the dc, a camera so the dc had image and cross hairs. It was not terribly accurate, but would do great for trees.
Posted : September 5, 2017 4:52 pm
Crashbox
(@crashbox)
A Schonstedt "stone with 'X'" module for my GA-52Cx locator.
GPS that would work ANYWHERE, with the precision, accuracy and speed of a good robotic TS.
Stakes and lath that you could add/correct/change the writing on, remotely.
Probably a few others I can dream up, but I had better stop while I'm not banned 😉
Posted : September 5, 2017 5:17 pm
shawn-billings
(@shawn-billings)
The Leica Disto 3D is pretty close to a good external DC mini total station, but they pursued builders and architects with it. Close but not quite.
Posted : September 5, 2017 5:58 pm
USSurveySupply_8668778783
(@ussurveysupply_8668778783)
Nate,
have you heard of the "All Materials Locator" from Subsurface Instruments? They have two options, the AML Pro and the AML+, both of which are capable of what you mentioned. We had one of these in for testing and found it to work as advertised, although it is definitely an acquired skill. It helps to know the general location of what you are looking for because it'll pick up roots, rocks, and other hidden objects.
Posted : September 6, 2017 5:20 pm
