Today's Pin Cushion
15 Users
(@mccracker)
This is on a right of way at a P.C. of entrance to a side road. The main road is rather busy but is still only two lanes and the side road is a small residential road in a platted subdivision. We are surveying a lot between this side road and the next one to east, for a new seawall permit. The ole' schonstedt went to a singin' when I got close.
Upon further inspection and depending on the angle you look at them, one of them is more straight up and down than the other. Oddly enough when I dug down a little more, they were wrapped around each other and all had different colors of survey ribbon. In this case, I located the center of the cluster, because that is where I presume them all to annotate.
Posted : 06/06/2016 6:02 pm
(@rich)
Nice!!!
Posted : 06/06/2016 7:11 pm
The more, the merrier!
"Found cluster of 3 Iron rods"
Posted : 06/06/2016 8:02 pm
(@stephen-ward)
Remains of a concrete monument? I've seen the twisting you describe when a bush-hog gets a hold of a concrete monument, shattering the concrete and twisting the rebar.
Posted : 06/06/2016 9:25 pm
Stephen Ward, post: 375934, member: 1206 wrote: Remains of a concrete monument? I've seen the twisting you describe when a bush-hog gets a hold of a concrete monument, shattering the concrete and twisting the rebar.
That's what it reminded me of too.
One bag of Sakrete, a little water, and a shiny new 3å? inch diam "stem Cap," and you're good to go.
Posted : 06/06/2016 9:29 pm
(@second-generation)
Being from Florida and so close to Disney world. We call that a Micky mouse corner.
Posted : 07/06/2016 2:18 am
(@mccracker)
I thought it could possibly be a broken monument also, but these were a variety of 1/2" and 5/8" of different levels of rustiness.
Posted : 07/06/2016 3:00 am
(@dan-patterson)
eh...just locate the one that isn't bent and forget about the other two. How much of a difference would it make anyway?
How do these things get pin cushioned so bad all the time? What are these people doing?
Posted : 07/06/2016 3:19 am
(@bushwhacker)
If this was in Texas it would be easy to decide which one to hold. Just figure out which one was set by a guy Texas AM or in Louisiana the guy from LSU since they are always correct.
Posted : 07/06/2016 3:49 am
Brian McEachern, post: 375940, member: 9299 wrote: I thought it could possibly be a broken monument also, but these were a variety of 1/2" and 5/8" of different levels of rustiness.
A little spendy, but I would just jam all three of them in one of these and forget about it
dimple if you think it's important.:whistle:
Posted : 07/06/2016 5:32 am
You run those through Star*net yet?:-D
Posted : 07/06/2016 5:42 am
(@flga-2-2-2-2-2-2-2-2)
Second-Generation, post: 375939, member: 1477 wrote: Being from Florida and so close to Disney world. We call that a Micky mouse corner.
If it is/was this thing would be somewhere around! 😉
Posted : 07/06/2016 6:50 am
(@jaxsmitty)
Would also think this was the top of a broken mon. Dig it up see if you find any conc around the bottom. Old mons weren't cast with the same lengths of rebar.
Posted : 07/06/2016 12:10 pm
(@skwyd)
FL/GA PLS., post: 375967, member: 379 wrote: If it is/was this thing would be somewhere around! 😉
I don't have access to the picture, but I did take a picture of a similar monument in Disneyland in Anaheim a couple of years ago.
Posted : 07/06/2016 1:13 pm
(@toivo1037)
Original post: I don't call that a pin cushion, I call that agreement!
Just wanted to point out the (R) on the mouse monument. That company protects EVERYTHING and is absolutely ruthless.
Posted : 07/06/2016 1:20 pm
(@skwyd)
toivo1037, post: 376042, member: 973 wrote: Original post: I don't call that a pin cushion, I call that agreement!
Yep. Of course, that is one of the things about copyright laws. If you register a trademark (like those ears) you are required to actively protect it. If you don't, you risk losing the right to keep it.
Posted : 07/06/2016 1:32 pm
(@kkw_archer)
From my calculations the actual point appears to be 0.0026' N 75å¡21'13.26984" W of the original location of the rod with the orange/yellow flagging,.........which is probably over 5' from the current location because someone moved the entire corner brace with rod attached.
Posted : 08/06/2016 10:46 am
