The (Theoretical) Advantage of Aluminum Caps
5 Users
This is what about six years ago I concluded is the East corner of Adams, Beaty & Moulton Survey No. 141 as located in 1877 by Travis County Surveyor Jno. E. Campbell. The aluminum cap is affixed to a 5/8-inc rebar set in a drill hole marking the center of the mound as it was found in 1940 by a surveyor who tied it to nearby survey markers that are still in place. In the meantime, the mound had fallen into disarray, so I rebuilt it in the last reliably reported position.
It's also the Southeast corner of a certain 321.07 acre tract of land conveyed in 1960 by deed recorded in Volume 2269 at Page 103 of the Travis County Deed Records. Just to give the next surveyor a decent clue, I thought it would be a good idea to add a reference to that 1960 conveyance to the aluminum cap, but I wouldn't bet the farm on that corner being described any better in the future than "Found McWilliam Cap & Rock Mound". The idea is much better in theory than actual 21st-century practice.
Posted : June 26, 2016 8:10 pm
Dan Patterson
(@dan-patterson)
nice work
Posted : June 26, 2016 8:54 pm
not-my-real-name
(@not-my-real-name)
Nice survey work. I would be pleased to find a monument like that. However I am wondering what the difference is between a rock mound and a stone mound. Are you just following the descriptions left in the field notes?
Posted : June 27, 2016 9:05 am
Howdy Kent,
What about a little flagging wrapped around that rebar?
It does serve a purpose.
Posted : June 27, 2016 9:51 am
not my real name, post: 379194, member: 8199 wrote: Nice survey work. I would be pleased to find a monument like that. However I am wondering what the difference is between a rock mound and a stone mound. Are you just following the descriptions left in the field notes?
As the term "stone" was generally used by 19th-century surveyors, it usually means a rounded field stone or cobble. "Rock" on the other hand usually described something with fractured faces.
Posted : June 27, 2016 9:57 am
Robert Hill, post: 379198, member: 378 wrote: What about a little flagging wrapped around that rebar?
Well, when you consider that when the capstone was replaced on the rock mound, you wouldn't see the rod and cap monument even with a whole roll of flagging wrapped around it, would the main purpose be to stimulate the sale of plastic flagging? The purpose of the rod and cap is to give a permanent reference point to the corner inexactly marked by the rock mound. I'll grant you that the 21st-century may well deliver survey parties who would not recognize a rock mound if it were in front of them, I'm not sure that flagging is a cure for that.
Posted : June 27, 2016 9:59 am
Kent McMillan, post: 379200, member: 3 wrote: Well, when you consider that when the capstone was replaced on the rock mound, you wouldn't see the rod and cap monument even with a whole roll of flagging wrapped around it, would the main purpose be to stimulate the sale of plastic flagging? The purpose of the rod and cap is to give a permanent reference point to the corner inexactly marked by the rock mound. I'll grant you that the 21st-century may well deliver survey parties who would not recognize a rock mound if it were in front of them, I'm not sure that flagging is a cure for that.
No, not really.
I can remember many a time digging for a corner and all that I found was small remnants of old flagging. Hmmm. So
It confirmed IMO, that the monument was removed at some point by someone somehow and they were not careful in their action. It is just another piece of evidence to leave for future a surveyor's benefit.
Posted : June 27, 2016 10:25 am
Robert Hill, post: 379205, member: 378 wrote: No, not really.
That particular rod that the cap is affixed to was driven into a drill hole in limestone. It would take a fairly major effort to pull it out. That is the upside to having shallow soil and a rock drill.
Posted : June 27, 2016 11:38 am
dms330
(@dms330)
If I recover a deeper monument of any type (it's almost always something with iron around here) I typically leave an upside down tail of surveyor's ribbon coming back towards the surface to give the next guy encouragement that he is going to find something useful. These typically aren't so deep that an additional new surface monument is warranted but sometimes that is also part of the program.
Licensed Land Surveyor
Posted : July 3, 2016 6:28 am
