Hi all
I now use survpc with my robotic leica 1100. I'm slowly figuring out how to do a feature survey with it.
Is it possible to have it in a display where you are not intending to store points but simply want it to display the bearings and distances while it follows you robotically?
This would be similar to the survey basic controler on the trimbles.
Thanks
Matt
Matt,
There is not screen that I know of that has the sole purpose of just giving angles/distances without any other command. You can view your angles and distances from the store points screen and just not actually store the point. Hit the yellow helment in the top, left and configure the menu in text view, instead of graph view and it may be easier to see. Other than that I use the remote screen a lot for this purpose. Go to your backsight screen, select the third tab over and you'll see this as well as some search commands in case the instrument loses you or you need to put it in standby,
Good luck.
Thanks for that. The more i play with it the more i like it.
