The correct tool for brushing line:
Is that your own D4D? ?????ÿ
Nice post!
It's the landowner's little cat. It actually proved to be inadequate, they worked the brush for a couple of hours and only got 100' or so. It was time to bring in a bigger one.
Mr. Moe,
Those original stones are the raw materials, of Surveyor's day dreams. Beautiful.
Thanks for sharing.
Nate
you need one of these
why did they only use a 1/4 of the stone and not the whole thing or maybe a 1/2 stone ?
James, because they were too heavy....
The?ÿstone?ÿor?ÿstone weight(abbreviation: st.) is an English and imperial unit of?ÿweight?ÿnow equal to 14 pounds (6.35029318 kg)
(Humor alert!)
Is that US Survey pounds or International pounds? ???? ???? ????ÿ
Arkansas uses the US Survey ones. Not international ones....?ÿ
It's only a gram or 2 different...
116 corners, 1/64th corners are tiny!
I like seeing the different styles used by various surveyors. Here is a recent open top 4.
Wrong attachment for the CAT. Brush blade would work great in what I see on the other side of the meadow.
I have sat and waited on folks that insisted upon building the road as they went.
They don't understand that they can do that on the way back after simply getting the brush out of the way and get much line marked in a day.
