I was perusing a 1973 survey this weekend which described found or set nails, concrete mon's, iron pipes, et cetera and one item referred to as a "Hi-Boy". In my 25-years-plus of surveying or at least indirectly involved with same, I have never seen such a description. There is a specialized tractor known as a Hi-Boy but setting such an implement as a monument doesn't make a lot of sense (unless it was an axle from one). If anyone here knows what a "Hi-Boy" is surveying-wise, I would appreciate it. Definitely a new one to me, and quite possibly a local/regional term.
Thank you very much in advance.
SellmanA, post: 375768, member: 8564 wrote: one item referred to as a "Hi-Boy".
Where's it at; did you go looking for it?
If'n it's not to far, maybe I might go with you...:-)
Makes me remember my beer drinking days and "tall boys".
Or a "hi-boy" ford pickup truck
What is the context? Setting a corner or setting a traverse point?
Consider what a Hi-Boy table looks like.
I would surmise they set a traverse point and boxed it in with 3 or 4 tall lath and wrapped a ribbon cage around it.
Paul in PA, post: 375920, member: 236 wrote: Consider what a Hi-Boy table looks like.
Paul I remember Perry ??? The rplser from the northeast NH I think describing running traverse thru the woods. They'd cut off a 4" tree on the line and leave it up about 3.5 ft. And put a nail in it with some shank exposed -the gun could set over it and it functioned as the backsight on it's own -no need to retrieve a piece of equipment. I wonder if that is the case here?
Rankin_File, post: 375925, member: 101 wrote: Paul I remember Perry ??? The rplser from the northeast NH I think describing running traverse thru the woods. They'd cut off a 4" tree on the line and leave it up about 3.5 ft. And put a nail in it with some shank exposed -the gun could set over it and it functioned as the backsight on it's own -no need to retrieve a piece of equipment. I wonder if that is the case here?
They called that a "high point", I believe.
I shot an e-mail to one of the surveyors whose stamp was on the ROS and is still practicing, and he very kindly responded.
Apparently, a "Hi-Boy" was an elderberry or alder staff about 6' long or so and placed alongside a property corner or line stake, with flagging as high up on it as possible.
Mystery solved.
SellmanA, post: 376028, member: 8564 wrote: Apparently, a "Hi-Boy" was an elderberry or alder staff about 6' long or so and placed alongside a property corner or line stake, with flagging as high up on it as possible.
I was told, in Western Washington, that this was called a "Baldy". Must be a regional thing...B-)
That be Perry Williams.....stand up bass player and surveyor....wonder what he's been up to....
RADAR, post: 376053, member: 413 wrote: I was told, in Western Washington, that this was called a "Baldy". Must be a regional thing...B-)
Perhaps it's a follicly-challenged, vertically-gifted male youngster? Ya gotta wonder...
Could have guessed for a week and not come up with the correct answer.
Holy Cow, post: 376081, member: 50 wrote: Could have guessed for a week and not come up with the correct answer.
Which is why I'm thankful the PLS responded. It would be great to have a database of some sort with local/regional/colloquial terminology of various surveying terms cross-referenced; it could be of considerable benefit IMO for those who need to find and retrace the footsteps of surveyors past.
I have heard them called "Forest Service hubs" in King County.
It can be most troublesome when various assorted items are called out on ROS's using local terms versus a specific, broadly-understood identifier. Ambiguities result if positive identification becomes lost to history; in this case, I was fortunate.
That would have been my guess, but I didn't think it would have been something typically reported on a record of survey. Around these parts we call it a high pole and set them typically in the woods as witness posts for better visibility.
While we're on the subject of regional terms and abbreviations, my extended family had a survey done in New York state and they sent me a copy of the survey. On it, all corners were abbreviated. Some with "IPF" (simple enough to decipher), but a couple were labeled "IPFF". Couldn't figure out what that meant, maybe just a typo?
Iron pin found f***ed up.
"Iron Pipe Found Flush (with ground)", perhaps? More likely a typo unless the height of others were called out.
