Seeking advice on purchasing a basic total station setup (reflectorless/prismless), software & controllers.
5 Users
keithsCADservices
(@keithscadservices)
I've read past posts which have been invaluable but also opened up a huge rabbit hole. I've also extensively researched some leads on how to get good deals on used equipment (which has become a sit and wait game). I've split my requirements into two:
Short term: I need a basic total station which only needs the following: It only has to be reflectorless/prismless (correct me if I'm wrong but those always co-exist?) and I need to be able to transfer data - no fancy software needed but I need to get the points off the machine into my PC. I would use this machine to both improve my own skills and potentially train new layout people. And maybe also as a back-up unit. Manual is okay here and perhaps even preferred since less can go wrong. There's currently a decent option in the buy-and-sell section.
Longer Term: I want to find myself a deal on the most basic of robotic setups. I should probably start a post exclusively for this. Prior to today I thought I had this figured out, but after reading through this forum I realize that there is an infinite amount of options as it pertains to total station/controller options. I don't need the latest and greatest, I just need 'control' and the ability to get points from the machine to my PC (and vice versa). My conclusion is just to do my research and sit and wait for a decent deal to appear, but of course I'm new at this.
Regarding software: I am pretty good with CAD, and the jobs I will work on are quite simple. And we're pretty good with pre-planning. I do AutoLISP and a little bit of .NET programming so any sort of processing of points can be handled on that front. I really won't ask much from my field software and therefore can't justify the price tag. I'd be looking to leverage this to try and save money on a controller/software setup.
This turned into a bit of a novel so much appreciation to anyone who read the whole thing!
Posted : June 17, 2022 11:20 pm
anonymous_9036
(@Anonymous 9036)
Prism less/reflectorless are the same thing. If you're doing that a lot go with Leica or geomax.?ÿ
How about a used Leica 1200 or a geomax zoom 80 and a used Panasonic fz-m1 toughpad windows 10 tablet running fieldgenius (what I've been using the past couple years now) or Carlson survPC.?ÿ
My company has "upgraded" me to a Trimble s5 and the reflectorless is terrible among other things.?ÿ
Posted : June 18, 2022 11:46 am
My "extremely out of date" advice is Leica... They were right about narrow beam being better.
I don't know if any others have gone narrow beam, but if they have, it might be worth looking at.
Narrow beam allows you to take a shot, where you want the shot taken. Broad beam forces you to never really know where that return signal came from. Some older Leica units allow more brands of data collector.
Nate
Posted : June 18, 2022 12:34 pm
For a reflectorless non-robotic one of these Nikons might be the ticket:
Posted : June 18, 2022 1:45 pm
anonymous_9036
(@Anonymous 9036)
@nate-the-surveyor?ÿ
Exactly. The Leica TCRP1203+ I've been using will run on Leica captivate, smartworx, Carlson, fieldgenius, even Trimble Access (tried it on the tsc5 for an hour one day).?ÿ
Reflectorless is very frustrating to use on the new Trimble after using that one so frequently.?ÿ
Posted : June 18, 2022 2:11 pm
keithsCADservices
@350rocketmike
But not this geomax? 😉
https://www.ebay.ca/itm/255433316200?hash=item3b79031768:g:iSgAAOSwlKNiLZFa
I've noticed that many companies are 'paired up' with another ie Topcon/Sokkia. And Hilti just has Trimble guts?
@nate-the-surveyor
This would be a huge plus! So older stations are more friendly with multiple controllers, but newer Leica stations not so much I guess? I did read a post exclusively on that subject. I only need to transfer points but extra features at extra marginal costs would be welcomed.
@mark-mayer
I've heard good things about these too! They are a little bit elusive locally, but if one comes up for sale I'd jump on it pretty quick.
Posted : June 18, 2022 4:09 pm
keithsCADservices
I forgot to ask:
Using a manual reflectorless total station, is the controller absolutely necessary? Eon's ago, I recall using a total station where we actually just grabbed points from a USB stick. I might be forgetting something, but I recall that we didn't need a controller and (I think) all the software was just built in - that is to say if you simply wanted to get the points off the machine and into a CSV file on your PC you could do that without anything more than either an SD card, a USB cable or USB stick. Unfortunately, this was so long ago that all I can remember from that unit is that it was yellow :-S .
Posted : June 18, 2022 7:00 pm
anonymous_9036
(@Anonymous 9036)
@keithscadservices?ÿ
Leica ts16 works fine with fieldgenius on a Panasonic fz-m1 tablet and I assume with Carlson etc. You won't have the video feed or some other features without using Leica captivate, so maybe better to just buy a ts13 instead. Geomax should be close to the same as having the Leica that it's based on.
And yes Hilti is just Trimble guts AFAIK with a huge price tag.?ÿ
Posted : June 19, 2022 12:13 pm
Posted by: @keithscadservices
That screen cap is from the Allen Precision Equipment website.?ÿ Talk to them.
Posted : June 19, 2022 12:34 pm
Yes. The latest units have exclusivity, lacking in the older units. Parts aren't available for older ones. My take is: find an older Leica, and data collector, that I like, and after you get comfortable, buy another. The logic being that you can buy 2 older guns, and data collectors, for less than one new one.?ÿ
Of course it won't be the latest gun, but, from your post, you don't need that.
Posted : June 19, 2022 1:14 pm
cf-67
(@cf-67)
Yes you can use the onboard software to do basic point collection and stakeout - no data collector necessary for simple tasks. And yes, they all can upload/download to PC one way or another.
Each manufacturer has their own quirky (usually) on board software that isn't always intuitive or user friendly - but if you learn the quirks, they work.
I find, because I need bifocals, I get a sore neck looking at the onboard screens, so I prefer a data collector, but that's just me.
Posted : June 19, 2022 1:27 pm
keithsCADservices
@mark-mayer
I found one a few hours away with FieldGenius installed. Almost a too-good-to-be-true price. More like an as-good-as-it-gets-price. I just have to find the time to drive there.
@nate-the-surveyor
I like that idea! And really, if a guy is into deal finding (which I'm kind of enjoying) they can save a lot of money. I'm scared to invest a lot of money into one setup for a few reasons, but mostly because it would become an "all eggs in one basket" scenario due to the cost. With a $30,000+ setup you have to worry about theft, damage, and even it breaking (rare but not unheard of with newer equipment). In my field, something is going to get trashed every few years. We also barely even need a robotic.
@350RocketMike
Those tablets also seem quite common which is a plus. Most the controllers I've held feel kind of like junk. I'm sure these tablets bite the dust every now and then but you could get 4 for the same price as one controller that bites it just as often. I'm now leaning towards using those in my setup unless I get a deal on a package of some kind. FieldGenius looks pretty good. It's expensive but everything is these days. Software is the one area where I haven't done much research yet.
@cf-67
Thanks for your answer. That adds a whole lot of clarity to something I've been trying to figure out for the last two days. I guess since many of the most basic features are standard they aren't actually advertised.
Thanks everyone for all the assistance!
Posted : June 19, 2022 2:31 pm
anonymous_9036
(@Anonymous 9036)
We paid $800 Canadian for our Panasonic tablet 2.5 years ago (already a few years old at that time). Still going strong and feels like it will never die. We did get an extended battery which can last 2 days if you're careful.?ÿ
Fieldgenius is very simple to use (imo) but will crash several times a day when used heavily (doesn't sound like you would be using it that hard). The Panasonic will reload the software and fieldgenius reconnected again within about 10-15 seconds and the Leica doesn't stop tracking you when the software disconnects, so it's not a huge deal.?ÿ
Posted : June 19, 2022 3:14 pm
