Removing Keel Marks
20 Users
Here's a new one for me: I just finished a boundary and topo of a small and somewhat down-at-the-heels apartment complex in town. I used yellow keel to highlight a handful of control points and as taping marks in maybe a dozen spots while filling in details during the field check. I just got email from the owner asking if it was okay for him to remove my "chalk marks." I wouldn't have thought that anyone would find those marks very noticeable, let alone objectionable.
Posted : July 19, 2017 8:30 am
OCD?
Posted : July 19, 2017 8:50 am
Jesusfreak
(@jesusfreak)
Did you tell him sure, or question why he wants them gone?
I had a crew that painted a white vinyl fence pink every 30' along it. They were using their paint marks to get their topo grid straight!!!! The owner called me and was furious (rightly so). So I had the crew with cleaner and brushes go scrub the fence. It took them 4 hours to get it all clean.
Posted : July 19, 2017 8:57 am
larry-scott
(@larry-scott)
Ah, spray paint. The surveyor's graffiti.
A very good survey and a very upset client.
Posted : July 19, 2017 9:25 am
Jp7191
(@jp7191)
I had the same surprise once. We were leaving blue keel marks on a concrete tilt-up building for finish surface of the parking lot. The super was all kinds of upset because paint does not stick to the waxy surface. Makes since! I thought I was doing good using keel! Learn something every day. Jp
Posted : July 19, 2017 9:51 am
john-putnam
(@john-putnam)
One word. Chalk!. Paint or stick.
Posted : July 19, 2017 10:02 am
john-putnam
(@john-putnam)
Pet peeve of mine is seeing little white dots all over the place when some careless crew has to mark each shot they have taken.
Posted : July 19, 2017 10:04 am
mkennedy
(@mkennedy)
My guess is his tenants are noticing them and panicking that he might sell the place...or otherwise make it even less inhabitable.
Posted : July 19, 2017 10:27 am
My guess is they wouldn't have noticed the marks if they hadn't seen the field crew making them.
Posted : July 19, 2017 11:50 am
Steve D
(@steve-d)
Depending on all of the variables; I sometimes drop a square of toilet paper at each shot. It is visible and bio-degradable. Recommend the cheapest I can find. (Also works well for recon or trial lines.)
Posted : July 19, 2017 12:02 pm
Ric-Moore
(@ric-moore)
Steve D, post: 437665, member: 433 wrote: Depending on all of the variables; I sometimes drop a square of toilet paper at each shot. It is visible and bio-degradable. Recommend the cheapest I can find. (Also works well for recon or trial lines.)
How would one know that was you and not some random bear that likes a certain brand of toilet paper? :p
Posted : July 19, 2017 12:23 pm
jph
 jph
(@jph)
Had a job years ago, running control for a new sewer line through a mental hospital compound. The contractor wanted the bench mark elevations of the hydrant bolts written on the hydrants. The residents complained so much that we had to go back and wash them off. No idea how they handled it when the construction started.
Posted : July 19, 2017 4:39 pm
Did a job years ago -an apartment being turned into a Condominium. We were instructed not to use any paint, flagging, lath, nothing. They didn't want us to even set any nails (we talked them out of that on the condition that we used the smallest nails possible).
Posted : July 19, 2017 9:53 pm
spledeus
(@spledeus)
Mark Mayer, post: 437746, member: 424 wrote: Did a job years ago -an apartment being turned into a Condominium. We were instructed not to use any paint, flagging, lath, nothing. They didn't want us to even set any nails (we talked them out of that on the condition that we used the smallest nails possible).
Had a similar scenario on National Park Service property. We needed to stake a building for construction but they wanted to carefully excavate for historic treasures (I do not believe they found any). So, for this bathroom building, we set offset DHs in the curbs and small PK nails in the asphalt walkways a good 150' beyond the small building. It worked well enough... Now that I think about it, I am not sure why they even needed a layout. The building is far enough away from everything else and is offset from the curb line. I think we wasted some government dollars but not as much as those archaeologists who did not find treasure under the NPS Bathrooms... There's gold in those hills somewhere.
Posted : July 19, 2017 10:56 pm
Steve D, post: 437665, member: 433 wrote: drop a square of toilet paper
I can just see this.
Somebody driving by sees you pulling out the tp roll, then they roll on, and ASSUME the rest of the story!
Posted : July 20, 2017 4:35 pm
Nate The Surveyor, post: 437890, member: 291 wrote: I can just see this.
ASSume
Posted : July 20, 2017 4:47 pm
dick emery
(@dick-emery)
Assume wind be the number 1 variable.
Posted : July 20, 2017 6:19 pm
Tom Adams, post: 437893, member: 7285 wrote: ASSume
I can just hear this uppity reel estate lady, talking with her co-conspirator, and telling the story, "I saw this guy in an OPEN field, doing his business.... and get this... it was a SURVEYOR!!!,,,,,..."
Posted : July 20, 2017 6:47 pm
2xcntr
(@2xcntr)
Thought it was kiel..... keel is that thing on the bottom of a boat.
Posted : July 21, 2017 6:45 am
True story:
I once had a co-worker that was convinced spraying his clothing with 'Deep Woods Off' would stain his khakis...so he was in the habit of pulling two or three pieces of TP off the roll (that is only in the back of the truck when you DON'T need it), and then spraying them down with Off after he tucked them into his back pockets so they would hang about the back of his knees.
We all were used to seeing him with his TP drifting behind him as he walked. He and the client that had met us out on the job wound up in a conversation and the client kept craning his neck around to look at the butt-wipe that was hanging from my (oblivious) co-worker's back side. It was hilarious to see.
Posted : July 21, 2017 7:23 am
