Pocket sized iron finder
11 Users
JB
 JB
(@jb)
The post about the Javad pin finder got me thinking that it would be awful handy to have something like that for when the iron you found is not "the one" and your detector is back in the truck.
Has anyone tried one of these?
http://www.garrett.com/hobbysite/hbby_pro-pointer_at_main_en.aspx
Seems pretty short range, but if you just needed to poke around a pre-calculated area it might do the job.
Posted : January 25, 2017 8:19 am
Following this thread with interest. Thanks JB.
Posted : January 25, 2017 8:30 am
I have a pinpointer that goes with me most places. It's great for corners near metal fence posts, but the range is about 0.15'. It's main purpose is to keep you from scraping up or missing valuable objects like coins or jewelry.
Posted : January 25, 2017 8:57 am
marblemapping
(@marblemapping)
I also have a garret pinpointer. Definitely has a very short range.
Sent from my SM-G930V using Tapatalk
Posted : January 25, 2017 10:48 am
I have asked Shawn Billings, and encouraged the Javad bunch, to MAKE an app, that would allow you to use the Javad Metal Detector, with a smart phone. Also, I'd like to see a small mini handle, that HOLDS the cell phone, (like a selfie stick holds a cell phone) and a little threaded screw to attach the Javad detector. This way, it would function alot like a "normal" detector, when desired. It could be 30" or 40" long.
But, you could leave the little handle device, (with the cell phone holder), in the ATV, or truck.
And go to the boonies. You could leave the cell phone in your pocket, and use just audio.
I'm trying to make it so that somebody with ONLY Javad, does not need another metal detector.
I don't know if they will do it, but I have asked for it.
Nate
Posted : January 25, 2017 10:58 am
JB
 JB
(@jb)
I've used my iphone's compass in a pinch a few times. Turn it on and hover a bit off the ground and you will get it to spin pretty good if pass over an iron.
try it next time you recover one the right way.
Posted : January 25, 2017 7:38 pm
I don't know if Javad has figured it out yet, but, if he does not make an app for his little bitty metal detector, he forces us to carry our old one too.
Drive up to job, grab metal detector, and go searching, and digging etc.
But, with his paradigm, we have to BOOT UP the LS, and assemble it, before we can use it. Boot up takes about 1 minute, or 1-1/2 minutes.
After booted, you can keep using it. But, now we HAVE to tote the LS with is, to use the tip.
We want to be able to USE the tip, independent of the LS.
Posted : January 26, 2017 8:31 am
thebionicman, post: 410757, member: 8136 wrote: I have a pinpointer ....... the range is about 0.15'.
Which I presume means it won't detect an iron .2' below the surface.
Posted : January 26, 2017 8:40 am
Mark Mayer, post: 410918, member: 424 wrote: Which I presume means it won't detect an iron .2' below the surface.
Exactly. It does not replace old yeller. I use it up against fence posts and in mud or water. It will narrow down a spot before chiseling into pavement. It can be tuned to be less discriminating to get a little more depth but not much.
Posted : January 26, 2017 8:47 am
thebionicman, post: 410920, member: 8136 wrote: It does not replace old yeller.
Thank you.
Posted : January 26, 2017 9:32 am
kscott
(@kscott)
I carry and use a White's pinpointer. http://www.kellycodetectors.com/catalog/bullseye-trx-waterproof-pinpointer . It has an adjustable range of about 9 inches. Handy to carry and great to use around fences and other interferences.
Posted : January 26, 2017 11:36 am
Beer Legs
(@beer-legs)
Why not carry one of these?:)
Posted : January 26, 2017 11:52 am
jerry-hastings
(@jerry-hastings)
Beer Legs, I would bet that a bunch of younguns don't even know what that is up there. Much less as to how to use one. Thanks for the nostalgic moment.
Posted : January 26, 2017 2:17 pm
[USER=9996]@Jerry Hastings[/USER]
I can remember when a "Beer Leg" actually cost the Iman a 6pack for the crew to share at the end of the day.........
Posted : January 26, 2017 3:42 pm
Neil Grande
(@neil-grande)
Beer Legs,
What is that contraption? Voltmeter?
Posted : January 26, 2017 9:35 pm
Beer Legs
(@beer-legs)
That is a Dip Needle, used to find monuments back in the day. The Dip Needle is a compass pivoted to move in the plane containing the magnetic field vector of the earth. It will then show the angle which the magnetic field makes with the vertical.
We used to use one for locating monuments when I was on my first survey crew after I got out of the Army. Have never used one since.
Posted : January 27, 2017 5:49 am
