pics of metal structures for tripod!!
8 Users
(@tigre5000i)
I'm about to do a survey configuration and contours of a ranch of large but there is a problem .., the vegetation is high for about 15-20 feet, my question is ... have any idea how to make a structure metal approximately 10-15 feet and it put the tripod to make this contour lifting?? .....
prism ... the stick and is about 16 feet, how I can put an extension to make it grandde, no, 22-25 feet, I can think of pvc pipe ....
... any suggestions???
fotos de estructuras metalicas para tripie!!
estoy por realizar un levantamiento de configuracion y curvas de nivel de un rancho de grandes extensiones pero existe un problema.., la vegetacion es alta de aproximadamente 15-20 pies, mi pregunta es..., tienen alguna idea de como fabricar una estructura metalica de aproximadamente 10-15 pies y en ella colocar el tripie para hacer este levantamiento de curvas de nivel??.....
...el baston y prisma es de aproximadamente 16 pies, como le puedo poner una extension para hacerlo mas grandde, no se, de 22-25 pies, se me ocurre un tubo de pvc....
... alguna sugerencia???
Posted : October 19, 2013 9:39 am
Use a fiberglass rod adapter:
Posted : October 19, 2013 10:51 am
(@tigre5000i)
interesting ... any other ideas?
interesante..., alguna otra idea??
Posted : October 19, 2013 11:22 am
(@lawrence-long)
Put the prism on the threaded end of a 4' range pole section. Add however many 4' sections of the range pole that you need, then attach range pole section to a prism pole.
Posted : October 19, 2013 12:06 pm
(@tigre5000i)
that's good ...
Posted : October 19, 2013 12:22 pm
(@sir-veysalot)
Don't even need the prism. With some good retro-reflective tape on the backside of a 25' fiberglass rod, my Nikon 520 (non reflectorless) will shoot at least 600' with a 2" square at the top. Plus, the back of the ROD comes with a height graduation to measure clearances. Not good for control but topo might be OK
Posted : October 19, 2013 2:27 pm
I don't think my robot will track reflective tape. Never tried it, though.
Posted : October 19, 2013 3:48 pm
(@hub-tack)
Large ranch = LIDAR
Posted : October 19, 2013 4:20 pm
(@tigre5000i)
and to make a tripod structure, have any pictures??
y para hacer una estructura a un tripie, tienen alguna foto??
Posted : October 20, 2013 7:51 am
(@foggyidea)
One word, Bilby. Look up bilby towers
Posted : October 21, 2013 5:07 am
(@tigre5000i)
my god!!, that's too much ..., these photos give me good ideas .., have other suggestions??, just want to make a 10-foot structure ...
mi dios!!, eso es demasiado..., estas fotos me dan buenas ideas.., tiene otras sugerencias??, solo quiero fabricar una estructura de 10 pies...
Posted : October 21, 2013 7:02 am
Posted : October 21, 2013 8:22 am
(@tigre5000i)
:-O :-O :-O
Posted : October 21, 2013 9:03 am
(@tigre5000i)
do you think??, have a better idea?
que les parece??, tienen una idea mejor??
Posted : October 21, 2013 11:38 am
(@john-putnam)
The instrument operator platform should be separate from the instrument to limit movement.
Posted : October 22, 2013 9:02 am
(@foggyidea)
If you look real well at the Bilby tower you will see that it's two towers, one inside the other to avoid moving the instrument as John Putnam said in the previous post.
Posted : October 22, 2013 10:59 am
(@tigre5000i)
I find the image in Bilby tower
no encuentro la imagen en Bilby tower
Posted : October 22, 2013 5:14 pm
(@tigre5000i)
long ago had seen a picture in this forum, but can not find them ...
hace tiempo había visto unas imágenes en este foro, pero no las encuentro...
Posted : October 22, 2013 5:16 pm
