OK, I'll go first
10 Users
Tips and tricks. Use Star Tron in your chain saw mix.
Use Slime in your atv tires.
Don't set your GPS base near a metal roof!
:good::hi5::-P:plumbbob:
Posted : June 15, 2015 4:51 am
(@moe-shetty)
when taking RTK data collection, RECORD your raw data, not just the vectors. this gives the added versatility of importing CORS/RINEX with precise ephemeris and removing those pesky and often small uncertainties
Posted : June 15, 2015 5:04 am
If your raw data does not record your act of setting monuments, side shot them or whatever it takes for your raw data to make a record of what your did.
Posted : June 15, 2015 7:53 am
(@spledeus)
Carpenters measure twice and cut once. Surveyors just keep measuring and checking.
Posted : June 15, 2015 9:07 am
Nate The Surveyor, post: 322082, member: 291 wrote: Tips and tricks. Use Star Tron in your chain saw mix....
Use ear & eye protection when using the chain saw. The world has enough deaf & blind surveyors. Also chaps & gloves.
Posted : June 15, 2015 9:18 am
Posted : June 15, 2015 9:19 am
Give me six hours to chop down a tree and I will spend the first four sharpening the axe.
Abraham Lincoln
Posted : June 15, 2015 10:53 am
(@rberry5886)
I give up, what is Star Tron? My chainsaw needs something....
Posted : June 15, 2015 11:32 am
Nate- were you trying to post in Tricks and Tips?
Posted : June 15, 2015 12:06 pm
rberry5886, post: 322228, member: 232 wrote: I give up, what is Star Tron? My chainsaw needs something....
Star Tron is one of many products use as an additive to gasoline to make it last and to keep your engine from gumming up from what is left of the gas as it evaporates and/or leaves residue inside the tank and fuel lines and filters.
I use SeaFoam :good:
Posted : June 15, 2015 12:20 pm
http://www.starbrite.com/en/startron
This is Star Tron. Sea Foam is good too. But, I can run Star Tron, and actually hear the motor start running better. It's an enzyme. I really like it.
Posted : June 15, 2015 4:09 pm
I thought I put this under "Tips and Tricks". Must be the first "Glitch". Ah, so what? I'm going to the river with the kids.
Posted : June 15, 2015 4:44 pm
Wendell
(@wendell)
Admin
Nate The Surveyor, post: 322338, member: 291 wrote: I thought I put this under "Tips and Tricks". Must be the first "Glitch". Ah, so what? I'm going to the river with the kids.
You did put it there but the Tips & tricks forum is an off-topic forum.
Sent from my Moto X2 via Tapatalk
Posted : June 15, 2015 4:55 pm
Don't leave chain saw in sun when you just used it, it could vapor lock next time you try to run it.
Posted : June 15, 2015 4:59 pm
