Monumenting Lines With Jogs
11 Users
BStrand
(@bstrand)
Member Debater
I've got a project where a farmer is splitting about 180 acres into several parcels. Per the owner's instructions one of the new parcel lines is supposed to follow the toe of a canal maintenance road. In the screenpic below the dashed blue line is the canal easement, the maintenance road runs along the inside of the southerly blue dashed line. I had my crew topo the toe of the road and the yellow line is the best fit line that I came up with to best follow the toe of the road without setting approximately 7 million pins out there. From L1 to L7 the line is a little over 1600' long and I thought it was a bit of an eyesore getting out of there with only 11 pins set, but I spoke with the farmer recently and he's concerned that in 1 spot there's a pin 6-8 feet from the toe of the road. Now I don't recall getting nearly that far away from the topo shots when I was calcing my line, but maybe I did (gonna check calc drawing here shortly). Or maybe the field crew missed a jog in the toe. But I mean this seems like a no-win situation. Either I set a ton of pins which looks ridiculous and probably confuses the hell out of everybody, or I get a phone call from the owner saying hey man, something isn't looking right...
Maybe it would have been possible to just call out the toe of the road in the deed description and not monument anything at all, but this is all ag land and these maintenance roads are basically just dirt berms that seem to get mauled by equipment or drift around over time.
Anyway, anyone have some sweet tips on how to make something like this happen without creating a pin farm?
(Also, why is it not possible to upload a .jpg, .png, etc which is probably the most common picture formats on earth...)
Posted : October 10, 2024 4:23 am
RoVaut
(@rovaut)
I think I might consider meeting the client on-site and setting the corners where the client agrees they should be located. Then, have the crew locate the points I set with the client present.
Posted : October 10, 2024 4:56 am
BStrand
(@bstrand)
Member Debater
That's a really good idea, should probably have done that now that I think about it.
Looking at my calc drawing the furthest I'm showing my boundary from the topo linework is 1.8 feet so I'm thinking the crew had a bad fix or maybe missed a jog or something.
Posted : October 10, 2024 5:05 am
dmyhill
(@dmyhill)
Supporter
I am very confused. If I was asked to divide property at the toe of a road I would do this:
Walk along the toe, setting rebar and cap at agreed intervals, locating those monuments. Then my description would be something like, "Thence (direction) (distance) to a rebar and cap set at the southwest edge of the road, being the toe of a slope;"
If the intention is to follow the toe, have the description follow the toe. Why not have the farmer put marks where they want the monuments, then set them in that place? Why would you shoot the thing and not put rebar in at the same time?
As for what to do now, put in pins. Put 20 of them in, who cares? They will not survive, based on your description of the way these are maintained. The way it "looks" is kind of irrelevant.
Posted : October 10, 2024 5:08 am
BStrand
(@bstrand)
Member Debater
The owner wasn't sure how exactly he wanted the parcels configured at the time he just knew he wanted the toe to be the line for part of it.
I think most surveyors in this state would view that that as creating an unnecessary pin farm mess, myself included.
Posted : October 10, 2024 5:35 am
Supporter Debater
Can think of a number of cases of the decades that where basically the same situation as what you are tackling. One was about two years ago where the owner was dividing about 60 acres following the toe of a berm forming one side of a waterway that ran completely across the tract of farmland. He was keeping one side and selling the rest. We started off using the longest straight run possible with the owner staying at the last point set until the next point to set was selected by my surveyor. Sometimes that would be 300 feet and some times it would be more like 50 feet. The client then set steel T posts near each bar.
One from about 45 years ago involved such modern equipment as the four-post transit originally owned by Thomas Jefferson and a 100-foot steel tape. One hundred feet between bars being set, with the transit always setting over the last bar set. Literally traversed the entire tract in this fashion. Area was hand calculated.
Posted : October 10, 2024 7:43 am
Supporter
I had a local attorney who wanted to split the old homestead. We started along the crest of the left side of a drainage, By the time he was finished I must have had 40 lath staked in the ground. His dad came out and blew up, "how much do you think brace posts will cost for this. We got the line down to 3 points.
Posted : October 10, 2024 8:31 am
OleManRiver
(@olemanriver)
Member Debater
Unless he specifically wants that toe monumented. With rebar or whatever. Just let the toe be the monument along the toe etc. I retraced a few boundaries that were written just that way. Now the pros are no driving a 100 rebar cons the toe can move but not much difference in that are along a creek at centerline or thread etc. plus natural monument is a great thing.
Posted : October 10, 2024 9:50 am
chris-bouffard
(@chris-bouffard)
Member Debater
The toe of the berm is not a natural monument and the way that the easement description may or may not change when the course of the canal does. It also relates to the intent, if the toe of the berm on the date of the survey was the intent of the boundary, the course of the canal shifting as a natural monument does not relate to the toe of the berm as the canal apparently is not called for as a natural monument and a man made berm certainly is not a natural monument.
Posted : October 10, 2024 10:16 am
OleManRiver
(@olemanriver)
Member Debater
Is it not natural because this is man made? I didn’t look to see if it was a man made berm. I was just reading the toe from his writing. A toe can be man made or natural might call it the foot of something. Same for a hill it can be made by nature or by man. So if not a natural in this case. It could still be used as a physical monument correct. Just like a fence if it is worded correctly.
Posted : October 10, 2024 10:46 am
WA-ID Surveyor
(@wa-id-surveyor)
I don't mind pin farms as long as they land on the land described. All lines are required to by monumented in most areas we work in. Could you remove the northern PC from C1 and straighten out the angle points between L4, L5, L6 and L7 and still meet your clients needs? That's the only way i can see to lessen the # of monuments.
Posted : October 11, 2024 12:17 am
BStrand
(@bstrand)
Member Debater
You're right that it's not a natural monument since the berm is manmade, but highways are manmade and can be monuments...
And yeah the easement is basically wherever the canal is.
The irrigation companies that manage these canals drive down the maintenance roads with a trackhoe every once in a while and groom the embankments so yeah I think both the canal and the road move slightly over time due to that, erosion, etc.
Posted : October 11, 2024 12:20 am
Supporter
I might simply call out the toe, setting a cap on it with a witness corner at the begin and end of the toe and describe it with B&D at the time of the survey. Treat it like a stream and if it's visible it's simple to follow in the field as a boundary. The caps along the way will leave the toe over time so it's just a snapshot of the toe the day it's capped, which can add ambiguity, where the call to the toe is clear. And I would include a reference in the description and the drawing that the calls along the toe are subservient to shifting of the toe location.
Posted : October 11, 2024 1:04 am
Supporter Debater
I encounter a LOT of boundaries tied to physical features of canals. The irrigation entities invariably treat them like an ambulatory boundary. In one case, they attempted to eject a farmer from the family home because it was 'within the easement'. They found out the hard way that canals are not riparian boundaries.
Without some very specific language, the toe (if called for) at the time of parcel creation is the line. If it moves, it is a disturbed monument. If the line as pinned is clearly identified as the line, it should prevent a lot of fights down the road..
Posted : October 11, 2024 3:29 am
BStrand
(@bstrand)
Member Debater
@OleManRiver Unless he specifically wants that toe monumented. With rebar or whatever. Just let the toe be the monument along the toe etc.
I'm in Idaho like WA ID and like he says lines are required to be monumented. I'm not really a fan of referencing something that moves around anyway.
@WA-ID Surveyor Could you remove the northern PC from C1 and straighten out the angle points between L4, L5, L6 and L7 and still meet your clients needs? That’s the only way i can see to lessen the # of monuments.
I can live with the number of monuments that were set, but I don't think the farmer wants to get any further from the toe than what it currently is.
In fact he told me a fence has already been built along this line (pins are set but survey yet to be recorded) and I was like dude... tell me about that first so we could have maybe stuck some lath out there to help you with this. The C1 curve is 363' long and I'm assuming the fence is basically on the chord which means there's already a discrepancy...
@MightyMoe And I would include a reference in the description and the drawing that the calls along the toe are subservient to shifting of the toe location.
I think the farmer thinks the toe won't move.
@thebionicman The irrigation entities invariably treat them like an ambulatory boundary.
That's how I tended to view them as well. The language I've seen on the department of water resources website and elsewhere seems to be pretty open-ended as far as what the irrigation entities can claim. Sounds like courts have knocked them down a peg or two in the past though?
Posted : October 11, 2024 4:33 am
Member Debater
My wife's family land is a mess in that the legal parcels do not line up with the creek, road, and usage, among other problems. She and her brother divided it by parcels when settling their mother's estate, but she owns ~3 or 4 acres of his cornfield, etc. I would like to have it replatted so the parcels made sense.
My question is: if I talk them i to it, would it make sense to ask for a riparian boundary along the lowest channel of the rather deep creek?
I mostly see reference to riparian boundaries in connection with rivers, so don't know if that would be "normal" here.
Posted : October 11, 2024 5:24 am
peter-lothian
(@peter-lothian)
Bill, here's a photo of a riparian boundary from my area. Definitely not a major river. As an intermittent stream, it has a clearly defined channel and enough flow to prevent the vibrant New England vegetation from taking root. It's stood the test of time as a boundary monument for well over 50 years.
Posted : October 11, 2024 5:35 am
BStrand
(@bstrand)
Member Debater
@bill93 My question is: if I talk them i to it, would it make sense to ask for a riparian boundary along the lowest channel of the rather deep creek?
I would suggest having the surveyor topo the top of bank on each side and then calculate an average centerline based on that. That's probably what the adjoiners are actively occupying anyway, right? And that way the surveyor can set reference monuments 10 or 15 or however many feet away where they won't get washed out.
Posted : October 11, 2024 6:17 am
Supporter Debater
Canal companies take a regular beating for attempting to steal land. I have to say it tickles me pink to see it happen. It is unfortunate the most common accomplice The Surveyor) rarely gets taken to task.
My take on canals is simple. We cannot apply the laws written to deal with natural water bodies to artificial bodies just because they look and act a bit alike. When irrigation works are called for in a deed they are treated like any other artificial monument. The position at parcel creation controls. If the owner tolerates movement for the prescriptive period, easement rights may arise. This requires a specific fact pattern, and the boundary does not move as the easement rights ripen.
Boundaries controlled by canals require extensive research. The older the parcel, the more research you can expect to perform. You may find the original location cannot be found with certainty. Most jump straight from reading the deed to making that determination. They take land from one person and assign it to another. That's not surveying.
Posted : October 11, 2024 6:23 am
Supporter
Ditches and canals are covered by statute here. There is a statutory easement granted, so it doesn't matter if they shift position, they are still inside the easement. But then water rights are a whole nuther subject for surveying. One interesting factoid is that if the ditch is buried and the conveyance is now transported through a pipe that pipe line needs an easement when the open ditch didn't.
Posted : October 11, 2024 6:28 am
