Leica tcr1105 not shooting?
11 Users
foggyidea
(@foggyidea)
Twice in the past week I have had instances of my gun not shooting a distance. No clicking, nothing. I switch back and forth between reflectorless and reflector, typically, on a job and in both modes the gun has not shot.
The first time I thought it might be something on the lens so I carefully cleaned the lens and it shot fine. The second time that didn't work, but re-booting the instrument did work. I was able to complete the day without further incident.
Have any others had this problem? Oh, by the way, the distances appear to be correct, the traverse closed well anyway. I'll take it to the shooting range (calibrated baseline) later today.
I run TDS onboard with this gun.
Dtp
Posted : November 18, 2014 9:32 am
surveythemark
(@surveythemark)
Donald,
It sounds like the EDM board may be on the verge of failing. On the TPS1100 there should have been one EDM board for the infrared and one board for the red laser. So it sounds like they both stop working for a moment which is odd too. I would think one mode, say infrared would give you trouble but not the board for the red laser. I am not sure if you are seeing both modes stop at the same time. In my experience usually once the EDM board starts to show issues it is not long before it fails completely.
I would prepare for getting it to Service.
Posted : November 18, 2014 11:48 am
foggyidea
(@foggyidea)
thanks for the heads up
Posted : November 18, 2014 12:21 pm
Check your co-axial alignment first. If it is out, well, there ya go! If not, well, it could be sompin else....
Posted : November 18, 2014 12:30 pm
Side Shot
(@side-shot)
foggyidea
Any chance the gun wasn't completely acclimated to
the colder temps this week ?
Was it right out of the truck or setup for awhile ?
I've had that happen on a TCRA1105 in the cold and a
reboot fixes it.
Posted : November 18, 2014 3:28 pm
foggyidea
(@foggyidea)
The first time it happened was about half way through a small topo where I had been switching between reflectorless and reflector. It happened once, just wouldn't shoot until after I cleaned the lens. I thought that maybe the humidity and temperature change had fogged the lens.
The second time was 3/4's of the way through a long traverse on a dry nice day, about 50 degrees.
It was the second time that I realized I didn't hear that clicking noise that starts when you hit the distance button.
I'm going to drop it off for service, and hope that they have parts if necessary!!
Dtp
Posted : November 19, 2014 7:15 am
foggyidea
(@foggyidea)
Leica tcr1105 not shooting?>UPDATE
So, it turns out that the board is going on my instrument. I can't afford a new gun at this time, still paying off the GPS from last year. So I am wondering if it's worth picking up a used 1105. I see them on ebay in the 3K+ range, although I seem to recall that the trade in value a few years ago was about 1K.
Does anyone have one they want to get rid of?
Dtp
Posted : November 21, 2014 7:31 am
IF its the board thats going... then a crashed inst would have the parts you'd need, and would probably be fine.
Somebody has one of those...
Posted : November 21, 2014 7:58 am
jerry-m-davis
(@jerry-m-davis)
Several years ago I had the EDM boards replaced on my 1103, it had past the end of life but I had kept it up with the modifications. So the new boards functioned with the upgrades I had done as they came along. These upgrades had been the fast track and the hot laser. I live in constant fear that when I take it out of the box and turn it on that it will fail. Electronics are fantastic but those old mechanical units are still operable and reliable. But, when you get used to the electronic Robotic units it is next to impossible to go back to manual data entry and an instrument man.
You might find a used 1103 or 1105 and get it and keep your old unit for possible parts. I would imagine there are so may different mods for the boards it would be impossible to tell which ones would fit.
Good luck is all I can offer.
Jerry
Posted : November 21, 2014 8:06 am
foggyidea
(@foggyidea)
Thanks Jerry, I'll let you know what happens.
Posted : November 21, 2014 11:05 am
Chris_1
(@chris_1)
foggyidea, post: 290597, member: 155 wrote: Leica tcr1105 not shooting?>UPDATE
All EDM boards looks the same but the difference is on the white label where you can find out "calibration #". By that # you can figure out what Voltage is used for EDM board service software need for that It can be #: 12, 14. 16, 18 . It means the EDM board from one 1103 could not work with another 1103. If EDM doesn't work on ant TPS series 99% is two motors are not working. Leica replaced whole board for a lot of $$$
but not any more. I did repair a lot of EDM boards just replacing the motors never got single come back. Best Chris
Posted : July 26, 2015 2:26 pm
Chris_1, post: 329156, member: 10265 wrote: All EDM boards looks the same but the difference is on the white label where you can find out "calibration #". By that # you can figure out what Voltage is used for EDM board service software need for that It can be #: 12, 14. 16, 18 . It means the EDM board from one 1103 could not work with another 1103. If EDM doesn't work on ant TPS series 99% is two motors are not working. Leica replaced whole board for a lot of $$$
Chris, I sure would like to have your contact information. I am running a TCA1100 (1998 model) on a daily basis, still. I worry about future trouble, with no one around to work on these. I do have a new robot purchase in the budget for next year, but if/when my old dark green Wild Robot ever gives up the ghost, it would be nice to have someone see iof they can get her back up and running.
Thanks, Brad
ott a t mainstreetconsulting daught c o m
Posted : July 26, 2015 2:36 pm
Chris_1
(@chris_1)
Hi Brad, am having at least 2 TPS1000 per week for service and repairs. In my opinion these guns are the best to trust on. If not mechanical damage happen you should worry only about internal memory backup battery. One day on the display you'll see one or two horizontal lines for 1-2 sec then empty screen. After replacing the battery the software has to be load from the scratch ...no problem with that. What you should do now if the gun works any extra programs you have loaded look for codes for each program and writ it down. All these codes will be needed for activating each program after repair. Leica doesn't have them any more or doesn't want to give help. Can contact me any time at: kwieclaw at yahoo dot com
Posted : July 26, 2015 3:28 pm
Chris_1, post: 329167, member: 10265 wrote: Hi Brad, am having at least 2 TPS1000 per week for service and repairs. In my opinion these guns are the best to trust on. If not mechanical damage happen you should worry only about internal memory backup battery. One day on the display you'll see one or two horizontal lines for 1-2 sec then empty screen. After replacing the battery the software has to be load from the scratch ...no problem with that. What you should do now if the gun works any extra programs you have loaded look for codes for each program and writ it down. All these codes will be needed for activating each program after repair. Leica doesn't have them any more or doesn't want to give help. Can contact me any time at: kwieclaw at yahoo dot com
e-mail sent.
Thanks Chris!
Posted : July 26, 2015 3:44 pm
Chris_1, post: 329167, member: 10265 wrote: What you should do now if the gun works any extra programs you have loaded look for codes for each program and writ it down. All these codes will be needed for activating each program after repair. Leica doesn't have them any more or doesn't want to give help.
How do I display these codes on my TCRA1102plus?
Posted : July 26, 2015 4:15 pm
RT Easy
(@rt-easy)
Please email me about a possible parts trc 1105
ncpls4248 At gee male
Posted : July 26, 2015 6:23 pm
Chris_1
(@chris_1)
Jim Frame, post: 329174, member: 10 wrote: How do I display these codes on my TCRA1102plus?
TPS1100 not so old guns Leica should help if not then PC with DOS can sniff for them. Each code will work on the gun according to serial # can't use them for another instrument
Posted : July 27, 2015 1:27 am
Ricardo Garay
(@ricardo-garay)
Hi Chris, I'm From Brasil and my Leica TCR 307 EDM doesn't work (msg: signal is too strong), do you replace the motor by cell phone vibration motors? What kind of motors do you use? Do you know where I can find the TCR 307 service manual?
Thanks in Advanced,
Ricardo Garay.
Posted : December 4, 2016 3:40 pm
Chris_1
(@chris_1)
Hi Ricardo, late replay but can give more idea. Service manual only at Leica but I don't think you'll be able to find this kind of help. Second ..nothing about EDM motors in service manual there is no serial or part # for motors at all. Where did you get idea about cell phone motors as replacement 😀 there are two types smaller for instruments up to 2008 and bigger till now.
Best
Chris
Posted : June 13, 2017 2:04 pm
Dan Patterson
(@dan-patterson)
foggyidea, post: 289943, member: 155 wrote: Twice in the past week I have had instances of my gun not shooting a distance. No clicking, nothing. I switch back and forth between reflectorless and reflector, typically, on a job and in both modes the gun has not shot.
Dtp
It sounds to me like it's time for a new gun.....have you considered financing one? I picked up a brand new Geomax Zoom 90 with a Carlson Surveyor 2, legs, pole, prism, everything. I think I am paying like $275/mo. It's really not that bad and productivity is way up as a result. I did put out a decent chunk as a down payment though.
Posted : June 14, 2017 5:29 am
