Good evening,
I'm new to Carlson SurvCE and used it to run a small RTK topo survey in my area using Topcon Hiper Pro receivers. I've downloaded the data into my desktop computer, and am reviewing the raw data in Carlson Survey. A portion of the RW5 data file is excerpted below. I would be very grateful for some review of this data, particularly as relates to base and rover height.
The base receiver was set up on a fixed height 2 meter tripod, over a point with known coordinates (PN1). The rover was set up on a fixed height 2 meter rover rod.
As far as I know, I entered the height of the base and rover receivers while in the field as 6.5617 feet. However, upon reviewing the raw data file, it looks like somehow a height of 6.909 was either entered or calculated, but I have no recollection of anything related to this in the field.
After setting up on the base, I completed a check shot (PN29) on another point with known coordinates (PN2). The check shot compared favorably, within a few hundredths or so.
Based upon what you see below, does it look like there was an error made with respect to entering the base or rover heights? If there was an error made, does that likely mean that the elevations/heights of the surveyed points are off by 0.3473 feet? If that is the case, what method do you suggest to correct the error?
I would very much appreciate any assistance on this matter, and apologize in advance for my apparent ignorance. Looking to learn. Thank you.
Big Al
JB,PROJECT,DT11-13-2012,TM00:08:13
MO,AD0,UN2,SF1.00000000,EC0,EO0.0,AU0
--SurvCE Version 2.61
--CRD: Alphanumeric
--MA Mainland NAD83
--Instrument
--TS Scale: 1.00000000
--Scale Point not used
--EDM Mode: Fine
SP,PN1,N 3042061.5110,E 366211.3880,EL177.4000,--irod w/cap
SP,PN2,N 3042831.7880,E 366629.2400,EL177.3800,--irod w/cap
SP,PN3,N 3044149.3430,E 367825.2580,EL176.9500,--irod w/cap
SP,PN5,N 3044485.9220,E 367617.8670,EL177.2470,--irod w/cap set
SP,PN6,N 3044525.9700,E 367843.2480,EL178.1290,--irod no cap
SP,PN10,N 3044470.5620,E 367603.7400,EL170.2600,--srch point
SP,PN20,N 3044588.6270,E 367968.2850,EL175.0420,--dh fnd
SP,PN21,N 3044588.6100,E 367968.3080,EL175.0420,--dh fnd
SP,PN26,N 3044572.1390,E 367957.1040,EL175.0790,--cu riv fnd
SP,PN27,N 3044572.1550,E 367957.0970,EL175.0790,--cu riv fnd
--DT11-13-2012
--TM10:23:36
--MA Mainland NAD83
--Equipment: HiPer Pro SN:T309-0284
--Localization File: C_DriveDataPROJECT.loc
--Number of Localization Points Used: 1
--Localization Scale: 1.00000000
--Geoid Separation File: C_DriveDataGeoid09.gsf
--Localization Azimuth: State Plane Grid
--GPS Scale: 1.00000000
--Base Configuration by Local Coordinate
--DT11-13-2012
--TM10:23:36
--Point Used: 1
--Coordinates Used: N3042061.5110, E366211.3880, Z177.4000
--Localization Used: C_DriveDataPROJECT.loc
--Base Rod Hgt: 6.909
--Antenna Type: [HIPER_PRO],RA0.0763m,SHMP0.0285m,L10.1060m,L20.0971m,--Topcon Internal
BP,PN1,LA42.352606427267,LN-72.343638013445,EL24.2606,AG2.000,PA0.106,--
--RTK Method: RTCM V3.0, Device: Internal Satel
--Entered HR: 6.5617, Vertical
LS,HR6.9094
GPS,PN28,LA42.352463581119,LN-72.343763291218,EL23.243136,--WMECO 70-6
--GS,PN28,N 3041918.0954,E 366115.8587,EL174.0636,--WMECO 70-6
G0,11/13/2012 14:26:44,Base ID read at rover: 0000
G1,BP1,PN28,DX-18.546,DY-36.299,DZ-33.139
G2,VX0.01746176,VY0.01221812,VZ0.01062018
G3,XY-0.00002933,XZ0.00001234,YZ-0.00005244
--GT,PN28,SW1714,ST224804000,EW1714,ET224804000
--HRMS:0.063, VRMS:0.047, STATUS:FIXED, SATS:16, PDOP:1.607, HDOP:0.865, VDOP:1.354
--DT11-13-2012
--TM10:28:43
GPS,PN29,LA42.353372500122,LN-72.343092496681,EL24.252861,--TEST PT 2
--GS,PN29,N 3042831.8361,E 366629.1910,EL177.3649,--TEST PT 2
G0,11/13/2012 14:31:46,Base ID read at rover: 0000
G1,BP1,PN29,DX70.764,DY189.888,DZ174.022
G2,VX0.01028030,VY0.01041202,VZ0.00871006
G3,XY-0.00001838,XZ0.00000935,YZ-0.00003529
--GT,PN29,SW1714,ST225106000,EW1714,ET225106000
--HRMS:0.041, VRMS:0.038, STATUS:FIXED, SATS:17, PDOP:1.356, HDOP:0.742, VDOP:1.135
--DT11-13-2012
--TM10:33:22
GPS,PN30,LA42.353044800429,LN-72.343150601012,EL18.830304,--CENTER CHANNEL
--GS,PN30,N 3042500.6634,E 366581.5500,EL159.5785,--CENTER CHANNEL
G0,11/13/2012 14:36:08,Base ID read at rover: 0000
G1,BP1,PN30,DX77.421,DY124.435,DZ95.910
G2,VX0.01057416,VY0.02282913,VZ0.01302030
G3,XY-0.00002053,XZ0.00001151,YZ-0.00003427
--GT,PN30,SW1714,ST225368000,EW1714,ET225368000
--HRMS:0.067, VRMS:0.064, STATUS:FIXED, SATS:17, PDOP:1.340, HDOP:0.721, VDOP:1.129
--DT11-13-2012
--TM10:37:30
It might be showing the height to the Antenna Phase Center.
6.5617 feet [sarcasm]WOW you are a good measurer![/sarcasm]
Just joking.
you would have to review the specs for your unit, and the settings for Carlson, but it appears that your 0.35' closely matches the 105.9mm L1 phase center offset. Might have something to do with that?
Best way is to just call or email Carlson. They are smart and very helpful.
This makes sense. I didn't recall entering the 6.909 height and the difference appears to be almost exactly the vertical offset between the ARP and the antenna phase center.
Thank you!
Yes, I checked the manual for the Hiper Pro, and the distance from the ARP to the L1 phase center is 105.9 mm up.
