geodimeter acting odd
5 Users
andy-j
(@andy-j)
Geodimeter 650, running with the Geo Orange CU.
Okay, not sure if it's me, the robot, or both of us having a brain fart. On a survey today, setup no problem, staked out a few points, measured some, then while staking another point, it just stopped finding the prism. Batteries seem to be charged, lights blinking, but will Not lock on the active 360 prism.
Any thoughts on what might be going on?? :-S
Posted : May 11, 2012 11:44 am
The Pseudo Ranger
(@the-pseudo-ranger)
Sounds like either the tracking mechanism in the gun, or the prism went bad. I had a prism that blinked (the little green lights) but still wasn't emitting the signal it looks for. Do you have an extra "brick" prism you can use to trouble shoot with, and see if it's the prism or the gun?
One other thing occurred to me on trouble shooting the 360 prism... hook the prism up to a power source and take it into a very dark room, like a closet, and see if it glows red. If not, it's the prism that's dead.
Posted : May 11, 2012 11:54 am
james-vianna
(@james-vianna)
Hi Andy,
I have had a similar problem in the past and narrowed it down to weak/almost dead radio batteries and or radio interference.
Jim
Posted : May 11, 2012 12:16 pm
andy-j
(@andy-j)
Dang TPR, why'd you have to be so right?? Oddly enough, I have a backup 360 that I forgot about. (a fellow surveyor dropped it off with some odds and ends to see if I wanted to buy them) So, I set up in the office, sure enough, no red lights in the prism and no tracking. Turned on the backup, Bingo!! tracking and red lights. I guess in the field I've never noticed the red, just the little green diode that blinks .
So, looks like I'm buying this equipment from my buddy!! But don't tell him that I actually need it now, he'll think about raising the price.
Andy
Posted : May 11, 2012 12:32 pm
The Pseudo Ranger
On my prism that went bad, I opened it up and found that little chip had come loose on the circuit board inside. I took it to place that fixes electronics and they soldered it back on, works good since then. Since you seem to have the same problem (green light, but no red light), it wouldn't hurt to take it apart and see if it looks good inside.
Posted : May 11, 2012 12:38 pm
andy-j
(@andy-j)
Yes, I've seen that too. Unfortunately, this is worse. Now if I could just figure out how to survey from my office, I wouldn't have to go back out in the blazing heat!
thanks.
Posted : May 11, 2012 12:39 pm
andy-j
(@andy-j)
sounds fun! thanks for the tip.
Posted : May 11, 2012 12:40 pm
Maybe this is a cry for help.
Have you considered getting it counseling? Perhaps you need some sort of couples couseling?
Posted : May 11, 2012 4:20 pm
andy-j
(@andy-j)
well, if it wants a raise, it can just forget it!! as my Dad always said.. "you can be replaced!"
Posted : May 11, 2012 4:27 pm
"DON'T LET THE DOOR HIT YOU ON THE WAY OUT!" was heard emanating from Andy's office.
Posted : May 11, 2012 4:46 pm
eddycreek
(@eddycreek)
NEVER DOUBT OLE #49!!!
nm
Posted : May 11, 2012 7:12 pm
andy-j
(@andy-j)
Bergstrand #49 is rocking!!! It's these Trimble pieces that are causing trouble!!!!
Posted : May 11, 2012 8:46 pm
