Geodimeter 600 Pro
2 Users
stuchtenhagen
(@stuchtenhagen)
We are trying to get a TSC2 working with our Robotic Geodimeter. I was told all we need is to update the PVX (??) board in the instrument, get a new cable to connect the collector to the radio, and it will work. Does anyone have a setup similar to this? I am currently running the face plate on the rod for my data collector. It is causing a lot of extra work for me and the draftsman on big topo jobs.
Posted : April 7, 2013 6:58 am
The Pseudo Ranger
(@the-pseudo-ranger)
What software are you running on the TSC2? I use a Ranger 300 (same hardware as a TSC2) with TDS Survey Pro 4 and 5, and it works fine with an Original Geo600. The only thing is that I have to manually turn on the radio at each set-up, since for some reason the automatic on/off stopped working with Survey Pro v4.
Posted : April 7, 2013 7:14 am
stuchtenhagen
(@stuchtenhagen)
Trimble Access
Posted : April 7, 2013 7:19 am
stuchtenhagen
(@stuchtenhagen)
So do you know anything about the PVX board, when you say original I am assuming you did not have to upgrade the board???
Posted : April 7, 2013 7:34 am
The Pseudo Ranger
No, it still has the original board. Does Trimble Access have Geo600 as an option, or are you trying to use Trimble5600 as the instrument setting? I have heard Trimble5600 boards were used as replacement boards in Geo600s, so it could be that to work with Trimble software you need a 5600 board.
Posted : April 7, 2013 8:00 am
