FL/GA PLS., post: 352567, member: 379 wrote: Don't know if this will help, but it's worth a try:
http://www.cutepdf.com/Products/CutePDF/writer.asp
B-)
Thanks.
We have this, it's in the same thing. It prints out pdfs from programs. This is what we use to make pdfs from Microsoft Word and Carlson
Any ideas on if they are going to make it into a Word format? Also, tried the CutePdf, doesn't work. Only works w/Acrobat. Talk about a monopoly...
Dan Patterson, post: 352639, member: 1179 wrote: And why is it 8.5x14" now? Just another nuisance.....I have to start buying legal sized paper now? I use 11x17 for small surveys and rolls for big surveys. I use letter size for just about everything else....
I wonder why the change to the paper size as well.
It is rare that we have to print anything on legal size paper these days.
even the deeds that are available on line and are scanned in at legal size, we still print to fit on a letter size paper and they are perfectly legible.
Dan Patterson, post: 352631, member: 1179 wrote: Why don't they just make a word form like they did last time? I CAN fill this out as a pdf, but it would be much easier if it were word format....
I converted them to Word for you using Acrobat, not always that good a conversion but these look OK. Too large to attach though but you can download them here.
https://www.sugarsync.com/pf/D3818606_06384068_666034
For those of you who can view the new form, is there any provision thereon to indicate the use of GRAV-D datum, or are they still requiring a physical "monument" only?
Jim,
Attached is a 'clip' of the form.
DDSM
squowse, post: 352768, member: 7109 wrote: I converted them to Word for you using Acrobat, not always that good a conversion but these look OK. Too large to attach though but you can download them here.
For some reason the text boxes aren't showing up allowing you to edit the file...
Roger,
Thanks! While you are at it, do you mind converting just pages 3-7 into a WORD Doc? That would be sweet!
hlbennettpls, post: 352827, member: 10049 wrote: For some reason the text boxes aren't showing up allowing you to edit the file...
in word 2013 you should just be able to type in the boxes but it won't be as well setup as if you do it in a pdf reader/editor.
Jason Graves, post: 352845, member: 9531 wrote: Roger,
you should be able to delete the pages you don't want?
I just contacted our local flood-plain coordinator (Louisville KY MSD), and they told me that the old certificates are still valid.
squowse, post: 352861, member: 7109 wrote: you should be able to delete the pages you don't want?
I tried your conversion and it dIdnt work well for me ... When I tried to edit the fields to add the data it would shift other text and check box features around in a way that doesn't make sense.
When FEMA created their word version of the old cert, the "locked" everything in place except the data fields .... I don't get the impression that a good form is easy to make, so I'm hoping FEMA will post a Word format when the update their official elevation certificate download page.
I do appreciate the effort, though.
Does somebody at FEMA have "silent financial arrangement" with someone at ADOBE. :whistle:
My Adobe XI Pro faultered after an update was installed on my Enhanced Dell hub computer. Will have to reinstall and forget the update.
Adobe XI Pro on the P6 Diamond opened the file with no problems.
I reckon not all motherboards are the same.........
Someone in this thread posted the new EC and when I opened it, it is a word document and on 8 1/2 x 11. I called FEMA and they told me as long as the insurer accepted 8 1/2 x 11 they are OK with that size. She did tell me FEMA is trying to be more "up to date" on paper sizes so my guess it 8 1/2 x 14 is "modern"? Gosh, maybe in the future we can hope to see 11 x17.
Using Adobe DC, (Adobe on-line Acrobat subscription), opens the pdf just fine, text entry fine, but same old problem with image inserts. Has anyone found a solution?
FL/GA PLS., post: 352999, member: 379 wrote: Does somebody at FEMA have "silent financial arrangement" with someone at ADOBE. :whistle:
I was wondering that exact same thing...
I wouldn't mind a PDF format if you can insert pics, save it, and edit it later. Seems like you can't do any of that ... easily, any way.
I'm going to keep using the last form until they update their official website. I'm still hoping they put out both a PDF and Word format, like they did last time ... maybe that is why they haven't posted the new el cert, yet, they are still working on the Word format.
http://www.fema.gov/media-library/assets/documents/160
It's funny that their site says it was updated Jan. 6th, but nothing is actually updated.
The Pseudo Ranger, post: 353109, member: 18 wrote: I wouldn't mind a PDF format if you can insert pics, save it, and edit it later. Seems like you can't do any of that ... easily, any way.
Noticed that, too.
Like you, I'm going to wait until it's replaced. I tried working with it last night, but got frustrated and quit.
Lamon Miller, post: 352166, member: 553 wrote: The new certificates are out.
http://nfipiservice.com/Stakeholder/pdf/bulletin/w-16002.pdf
Got this from our local City:
Good morning All,
Please follow the link below to download the new FEMA Elevation Certificate and Floodproofing Certificate.
The City of Pasadena, Texas requires this new form to be used for all developments within City of Pasadena's jurisdiction.
