elevation Certificate
25 Users
(@lamon-miller)
The new certificates are out.
http://nfipiservice.com/Stakeholder/pdf/bulletin/w-16002.pdf
Posted : January 7, 2016 12:28 pm
(@k-huerth)
Did they change it to legal size sheets only? or is there a different link to 8.5x11 forms?
Posted : January 7, 2016 1:06 pm
(@the-pseudo-ranger)
Hmmm ... the FEMA site that hosts the elevation cert is not updated. Hopefully they will put up a Word version ... I can never get the photos to insert into the their PDF forms, and it appears they can not be saved.
http://www.fema.gov/media-library/assets/documents/160
Posted : January 8, 2016 12:20 pm
(@stephen-ward)
The Pseudo Ranger, post: 352367, member: 18 wrote: Hmmm ... the FEMA site that hosts the elevation cert is not updated. Hopefully they will put up a Word version ... I can never get the photos to insert into the their PDF forms, and it appears they can not be saved.
The OP's link opens a pdf with a hyperlink in blue "Bulletin W-16002 Attachments" that will take you to the download page (form is not available on FEMA's site yet). The new EC is on a legal size sheet and was created by Adobe Live Cycle so no edits are possible even with Acrobat Pro (fill in the blanks only). The solution as I posted in another thread is to fill in the form then choose print and select Adobe PDF as your printer. This will output a flat pdf (no fields or security) then you can go to Tools, Content Editing, Add Image, and insert photos and add text boxes for photo descriptions on the appropriate pages of the EC. When finished, you can print to the Adobe PDF printer again to get a non-editable pdf for distribution or just send it to your regular printer for a hard copy.
The above directions work with Acrobat XI Pro but similar workarounds should work in other versions.
Posted : January 8, 2016 12:35 pm
(@rich)
They better release a word version as well.
I keep my word version saved half filled out. That way I don't have to keep filling in the repetitive fields every job
Posted : January 10, 2016 8:08 am
(@stephen-ward)
Rich., post: 352548, member: 10450 wrote: They better release a word version as well.
I just checked, with this current pdf version of the EC that has been release and using Acrobat XI pro, I can fill it in and save it.
Posted : January 10, 2016 8:39 am
(@rich)
Guess I gotta buy acrobat pro now. :-/
Posted : January 10, 2016 9:43 am
(@stephen-ward)
Rich., post: 352553, member: 10450 wrote: Guess I gotta buy acrobat pro now. :-/
Others on here use alll sorts of pdf writers with pretty good success rates. You might inquire if others are able to fill and save with lower cost pdf writers.
Posted : January 10, 2016 10:24 am
(@flga-2-2-2-2-2-2-2-2)
Don't know if this will help, but it's worth a try:
http://www.cutepdf.com/Products/CutePDF/writer.asp
B-)
Posted : January 10, 2016 12:14 pm
(@andy-j)
Lamon Miller, post: 352166, member: 553 wrote: The new certificates are out.
Thanks! Am I imagining this or do we only have to sign the new form ONCE?
Posted : January 11, 2016 3:30 am
We have Adobe Acrobat Xi and it is not opening...
Posted : January 11, 2016 5:48 am
(@gregg-gaffney)
Jim in AZ, post: 352619, member: 249 wrote: We have Adobe Acrobat Xi and it is not opening...
I just had the same issue but once I saved it to my computer it opened no problem.
Hopefully that works for you as well
Posted : January 11, 2016 6:00 am
(@jethro)
FEMA says
"Please make sure you are using Internet Explorer to open the forms."
Who knew.
Posted : January 11, 2016 7:34 am
(@dan-patterson)
Why don't they just make a word form like they did last time? I CAN fill this out as a pdf, but it would be much easier if it were word format....
Posted : January 11, 2016 7:40 am
(@randy-rain)
I wish that they had a red letter version like the new ALTA requirements, outlining and highlighting the differences.
Posted : January 11, 2016 8:44 am
(@randy-rain)
Andy J, post: 352610, member: 44 wrote: Thanks! Am I imagining this or do we only have to sign the new form ONCE?
Sorry Andy, looks like you still have to sign it twice. It just looks like now both signatures are on the same page....:-/
Posted : January 11, 2016 8:48 am
Dan Patterson, post: 352631, member: 1179 wrote: Why don't they just make a word form like they did last time? I CAN fill this out as a pdf, but it would be much easier if it were word format....
I agree, the "Adobe" crap they suggest downloading works except you can't save a copy.
At least I can't, any suggestions?
Posted : January 11, 2016 8:52 am
(@dan-patterson)
And why is it 8.5x14" now? Just another nuisance.....I have to start buying legal sized paper now? I use 11x17 for small surveys and rolls for big surveys. I use letter size for just about everything else....
Posted : January 11, 2016 9:07 am
(@dan-patterson)
have you tried PDF exchange viewer? I use that for most things. You can insert a picture with it as well, but again.....word is easier.
Posted : January 11, 2016 9:12 am
Dan Patterson, post: 352640, member: 1179 wrote: have you tried PDF exchange viewer? I use that for most things. You can insert a picture with it as well, but again.....word is easier.
Just viewed their website, going to try it out later (I'm on a Chromebook so it won't work on the OS), thank you!
Posted : January 11, 2016 9:20 am
Page 1 / 3
