Sorry Jeff @ MTS, I just couldn't resist taking apart the Nikon.
Is that before, or after, the washer & dryer?
You broke the seal, now what?
jud
Perry,
Is there anything that you can't do?:-P
Jimmy
Looks like the same gun I run with. Do you use the internal memory, or an external DC? Those buttons were obviously made by people with small fingers, and coding is like using an old cell phone.
Pretty much use the internal data collector, though I have hooked up an external collector to it occasionally.
> jud
I broke the seals on both keypads 6 years ago and no problems yet. (The Face1 keypad started screwing up, so I swapped the Face1 & Face2 Keypads.)
Looks like the DTM 520 I have. The only problem so far is the vertical sometimes falls; as you lock on the sight, it sometimes very slowly drifts down. I need to upgrade soon, what to get that is similar but with some-- say 500 to 600'-- reflector-less? I don't use the "on board" features much either; I'd rather have a DC or small computer in hand. Don Berry
Warranty Voided! :-X
It's a Nikon NPL 350. Reflectoless range out to 300' if you are lucky.
