Chains plus a faction part
11 Users
(@bridger48)
Deed has a number of distance calls in chains followed by a faction:
Example
"thence S.56°30'W. 30.80 1/3 chains to a basalt stone"
What is the distance in feet?
bridger
Posted : June 26, 2015 1:32 pm
(@kris-morgan)
2054.8??????
Posted : June 26, 2015 1:36 pm
(@alan-cook)
I came up with 2054.58'. Are all chain measurements the same? I used 66' for a chain.
And which faction are we dealing with, the international chain carriers? 🙂
Posted : June 26, 2015 1:45 pm
(@bridger48)
Kris Morgan, post: 324648, member: 29 wrote: 2054.8??????
Can't just smell those basalt stones like I use too. Here is the next distance call, "0.07 3/5 chains to the right bank of the Willamette River"
Posted : June 26, 2015 1:48 pm
 vern
(@vern)
I get 2033 feet and 5.02 feet. But i suspect we are not interpreting something right. Can you post the actual document?
Posted : June 26, 2015 2:13 pm
(@jbstahl)
The surveyor is using a chain with 100 8-inch links. He's pulling 30 chains, 80 and 1/3 links in the first distance and 7 and 3/5 links in the second. The fractional parts of the link are just estimates I'd imagine. Pretty easy to estimate a 3rd or 5th of a link.
Posted : June 26, 2015 2:20 pm
I vote with JBS and Vern. Calculator before rounding says 2033.020 and 5.016
Posted : June 26, 2015 2:30 pm
(@euclid)
I actually saw an antique "engineer's" chain today. The links were 1 ft long.
Posted : June 26, 2015 4:00 pm
(@bridger48)
vern, post: 324665, member: 3436 wrote: I get 2033 feet and 5.02 feet. But i suspect we are not interpreting something right. Can you post the actual document?
The Deed in question:
Posted : June 26, 2015 5:32 pm
I'm with Vern on this one.
Posted : June 26, 2015 6:45 pm
Guest
Euclid, post: 324683, member: 10127 wrote: I actually saw an antique "engineer's" chain today. The links were 1 ft long.
We had 100 link "chains" and 100 foot "chains".
To confuse, a Chain was/ still is 66', 20.1168 metres.
But 100 feet is just that, and we surveyed rural areas in links with towns in feet, but often a combination. Sounds confusing perhaps but not here.
However I've discovered errors in earlier surveys where it seemed obvious they'd surveyed with a foot chain and converted all to links. (Or vice versa)
I digress. Might get "Ignored" :whistle:
More digression. I see we now have categories of emoticons.
Posted : June 26, 2015 6:59 pm
(@harold)
I am going with the fractional part of one link.
Posted : June 26, 2015 7:03 pm
Types of field measurements vary too much, I would tend to use the calls as a guide. In no particular order:
11.175 chains = 737.55'
30.80 1/3 chains = 30.803 chains = 2032.00'
0.07 3/5 chains = 0.076 chains = 5.02'
then you have 2 ties to one point
.18 chains = 11.88'
149.5 links = 1.495 chains = 98.67'
and then the closing call
40.00 chains
which I doubt was ever measured in the field.
My first assumption in reviewing the deed is that the surveyor??? never ran any line in the field, instead taking all calls from adjacent parcels. Keeping that in mind there is most likely no single basis of bearings for this description.
Believe little, search far and wide.
Posted : June 27, 2015 1:22 am
(@bridger48)
I agree the surveyor may not have ran the complete description and the closure issues leads one to that conclusion. Thanks to all that offered input.
Posted : June 27, 2015 12:25 pm
