WINDOWS 2000 PASSWORD HELP
ekillo
(@ekillo)
Today has not been a good day so far, I needed to process some GPS data and try tried to boot my laptop that has the Leica LGO software on it that I normally use that has a parallel port for the hardware lock but the system battery was dead, so I tried to boot an older computer that has a parallel port on it that is running Windows 2000 and the password that I remember is not working. If I could find my software disks I would install on another computer that has a port for the hardware lock. My question is, how can I bypass the password for Windows 2000? TIA
Posted : August 30, 2013 12:36 pm
Wendell
(@wendell)
Admin
I've never had to do this, but maybe this little goodie will do the trick: http://pogostick.net/~pnh/ntpasswd/
Posted : August 30, 2013 1:30 pm
ekillo
(@ekillo)
Thanks for your quick response, as it turns out it is not always the obvious. The problem was not my memory but the keyboard on the old computer had a bad e key and was not entering the password correctly. After I changed the keyboard, my old password worked, but I have booked marked the site for future use, because of my age that could be sooner than later.
Posted : August 30, 2013 7:22 pm
Wendell
(@wendell)
Admin
Well I'm glad you were at least able to get it figured out. If nothing else, it was a great excuse to get a new keyboard. 🙂
Posted : August 30, 2013 7:56 pm
Sawnde
(@sawnde)
Here I recommend some popular solutions to help you bypass password on Windows 2000:
Solution 1 Bypass Windows 2000 password by another user account with administrator privilege.
Solution 2 Bypass Windows 2000 password with Offline Windows Password & Registry Editor.
Solution 3 Bypass Windows 2000 password with professional Windows 2000 Password Recovery Tool.
Posted : September 2, 2013 12:35 am
