Printing Transparency in Carlson Survey IntelliCAD 2016
5 Users
hillsidesurveyor
(@hillsidesurveyor)
Hi all,
I have been searching for a solution to this, but can't seem to find anything.
I have some solid hatching in my survey drawing and am able to give it a 80% transparency in CAD so that the underlying objects can be seen, but when I go to print the solid hatching prints dark with no transparency. I have tried checking all of the options available in the print options, but nothing seems to work.
Does anyone know how to print the hatching transparency?
Thanks in advance.
Posted : September 2, 2016 9:15 am
john-giles
(@john-giles)
Don't know about carlson but in autocad you have a display order'. Just send the solid hatching to the back. Also may be a pen issue. Change pen color to a lighter color. Don't know if you have all pens set to black. That can happen also.
Posted : September 2, 2016 9:36 am
Some printers do not support the transparency commands. We have a xerox that will only print 1" of the page if transparency is turned on.
I am forced to use the DWG to PDF driver then print from Adobe in order to utilize transparency. Crazy frustrating!
Posted : September 2, 2016 9:40 am
hillsidesurveyor
(@hillsidesurveyor)
I found the "Printtransparency" command and turned it to on, but it still doesn't work. I also tried to export to a PDF and the PDF also shows up pitch black.
I do have all of the pens set to black and have it on the lightest setting I use. When using Civil 3D there was a setting in the print menu on whether or not to print transparency, but there doesn't seem to be anything in IntelliCAD.
I also have tried the draworder command with no success.
Posted : September 2, 2016 9:46 am
N.W. Staker
(@nw-staker)
Have you tried changing the color from black to something else. I know ours seem to work like that.
Posted : September 2, 2016 10:03 am
hillsidesurveyor
(@hillsidesurveyor)
Jackpot
I changed the color from black to the object color and now it displays transparent.
Thank you very much, don't know what I would do without this board.
Posted : September 2, 2016 10:11 am
Tom Wilson
(@tom-wilson)
"Thank you very much, don't know what I would do without this board."
Let's hope you (we) never have to find out !!
T.W.
Posted : September 2, 2016 1:06 pm
