Need help finding Solar in Carlson Survey
Well, I should probably have known better than to think I'd come fully up to speed using Carlson Survey in 30 days, but I took the plunge anyway and instantly remembered what it was about ACAD I didn't like, like the 5 gazzilion tool bar icons and customizable menus (Where's the Carlson Reduced Complexity, Nothing but the Basics" configuration template when you need it?):-S
At any rate, I decided to focus on current needs (Least Squares and Solar) and tried to find the solar screens I think Lee Green used to double check his DOS program. I took my first batch on site this weekend, and reduced them using the DOS program, but want to see what Carlson comes up with.
I swear I've scrolled through every menu option, every tool bar multiple times, but can't find it. The maddening thing is I'm pretty sure I saw it somewhere last week, when I began.
Help?
Posted : March 13, 2016 3:35 pm
Pulldown Menu Location: COGO
Keyboard Command: solarobs
Posted : March 13, 2016 4:24 pm
Carlson 2009, I should add.
Posted : March 13, 2016 4:48 pm
Nate The Surveyor, post: 362110, member: 291 wrote: Pulldown Menu Location: COGO
Thank you. Nothing in "Help" though, for "Solarobs". I'll look on line.
Posted : March 13, 2016 5:10 pm
What version of CARLSON are you running?
Posted : March 13, 2016 5:13 pm
It's Survey 2016 with Autocad. I've looked through the directories that were installed to see if a full manual was downloaded with the install, but I guess not. I realize this might be a fool's errand, even with a full manual. There do seem to be a ton of support options on the website though. Slow slog.
Posted : March 13, 2016 5:24 pm
Here is a screen shot.
It's the 5th one up from the bottom.
Posted : March 13, 2016 5:29 pm
yswami
(@yswami)
Aloha, Robert:
Nate is correct. I have 2016...Solar Observation is there under the COGO menu.
Posted : March 14, 2016 3:30 pm
yswami, post: 362306, member: 7679 wrote: Aloha, Robert:
Aloha swami:
I found it and went through the process but can't find the results. After I enter the data for the last piece ("Enter angle to sun:), there's no results as in this screen shot from Lee Green. The bottom section is no where to be found. Anyone familiar with how it works?
Posted : March 14, 2016 4:24 pm
