Exploding blocks in Autocad LT 2010
7 Users
John
 John
(@john)
Hey kids, I have hopes someone here has encountered this issue before.
I brought in a couple drawings that the previous occupant of this seat drew and made into blocks. Likely done in an earlier version of ACad LT as well. Edit: I am using AutoCAD Light, so do not have all those fancy commands and macros everybody else here is likely to have! Please, as basic as possible.
Anyway, I am unable to explode the blocks for some reason. An internet search hasn't provided (useful to me) answers yet.
Anybody know the answer?
Thanks in advance!
Posted : March 14, 2016 12:57 pm
Warren Smith
(@warren-smith)
Are they on locked layers?
Posted : March 14, 2016 1:07 pm
peter-hughes-davies
(@peter-hughes-davies)
John, post: 362271, member: 791 wrote: Hey kids, I have hopes someone here has encountered this issue before.
Thanks in advance!
Minsert is a way to create a block that can't be exploded and is useful for making it difficult (but not impossible) to explode and edit a block. I don't know if it's available in AutoCAD LT though. What does it say when you list it's properties?
Posted : March 14, 2016 1:12 pm
John
 John
(@john)
I copied the drawings into my drawing. I can check the original to see if it is on a locked layer.
When I look at the properties for the drawing, I see the info about "general", Plot style, view (x/y/height/width) and misc (annotation, usc info).
Nothing jumps out at me on the properties.
Posted : March 14, 2016 1:27 pm
John
 John
(@john)
Odd. Seems like I did something when I blocked them. No idea what. I seem to be back in business.
Posted : March 14, 2016 1:45 pm
Bob Westerman
(@bobwesterman)
Are X Y and Z scales all the same? Far as I know the must be to be able to explode.
John
 John
(@john)
All the scales were the same. I had blocked the drawing to enable moving it around without losing a line segment or 3. I hadn't gotten to scaling any axis of the drawing.
Posted : March 14, 2016 2:00 pm
I have had problems editing existing drawings when I double click on the drawing file to open in Carlson or Autocad Map R2 (whichever one is set as default).
When I open Carlson or Autocad Map R2 and select to open a drawing and a selection box opens so I can choose a file to open, all my editing commands will work properly.
That is just how it does and I really don't know why......:-S
Posted : March 14, 2016 6:58 pm
billvhill
(@billvhill)
When I first installed Carlson with Intellicad, I too also had problems by double clicking the drawing file. Carlson would start in the trial version mode, but if I opened Carlson and selected the drawing it would open correctly. Since I upgraded to Carlson 2016, I do not have that problem anymore.
Posted : March 15, 2016 9:00 pm
Bimmel
(@bimmel)
I have not used a autocad light in a while but going on a hunch.
There is a property that can be applied to blocks making them explodable or not.
Go into the block editor and change the property?
Posted : March 15, 2016 10:08 pm
