I have a new drive that will have a different drive letter than the where all my projects are located. Is there a way to change default LDD project path?
Example: change from c:land projects 2006 to g:land projects 2006
In LDD2i it retains the last project drive & path that I used, so it's as easy as browsing to the new drive and path.
Have you tried typing "Options" and modified or adding to the paths listed there (under the "files" tab)?
Stephen, that worked, thank you.
That will also effect any xrefs you have with the old drive number and you will need to browse and reattach them. I think it is easier to "Map" the new drive using the old drive S: tag.
