Flipping annotations in Intellicad 10.1 and Carlson 2022
goodgps
(@goodgps)
Hi Again,?ÿ
I'm hoping someone may have encountered and solved the annotation issue with this software pair.?ÿ I'll label a line for bearing and distance but want the label to be on the other side of the line.?ÿ there is a "flip label" command but this simply does not work.?ÿ The Carlson team has no clue on this.?ÿ I've been back and forth with them.?ÿ No Luck Maybe there is a specific Technician I should ask for ??ÿ
Thanks?ÿ ?ÿ
Posted : May 25, 2022 12:05 pm
richard-germiller
(@richard-germiller)
On mine there are several choices on the Annotate dropdown>Flip labels>
Posted : May 25, 2022 12:54 pm
back-chain
(@back-chain)
Posted by: @richard-germiller
Agreed. Generally a combination of mirror/ mirror & flip... just keep it bouncing till it falls like you like it. I'm only as current as '21 on icad.
Posted : May 25, 2022 3:32 pm
ladd-nelson
(@ladd-nelson)
Posted by: @goodgps
Hi Again,?ÿ
<snip> The Carlson team has no clue on this.?ÿ I've been back and forth with them.?ÿ No Luck Maybe there is a specific Technician I should ask for ??ÿ
Thanks?ÿ ?ÿ
This sort of surprises me. If you'd like to back-channel me (lnelsonATcarlsonswDOTcom) with the DWG that is exhibiting the behavior, I'll take a look and elevate as needed.
Posted : May 26, 2022 3:08 pm
goodgps
(@goodgps)
@ladd-nelson?ÿ
Hi Ladd?ÿ It is all of the drawings.?ÿ A couple of other technicians?ÿ from Carlson reached out to me and told me they found the program glitch. They are working on a solution and will make a patch available after memorial day.?ÿ
I'm hoping this patch works.?ÿ
Have a?ÿ great memorial weekend?ÿ?ÿ
Posted : May 27, 2022 9:11 am
