Extract an .rw5 from a .survey file?
11 Users
RoadBurner
(@roadburner)
Anyone know how?
Posted : March 1, 2017 1:40 pm
Not trying to be a smartass here, but what is a ".survey file?"
Posted : March 1, 2017 1:42 pm
jph
 jph
(@jph)
It's one of the files from Survey Pro.
Looks to me like someone just dragged the files off off the DC without Extracting the .job/raw first.
If you still have the DC, do that. If you don't, I think that you'll need Trimble office software to get the raw from the .survey file.
Posted : March 1, 2017 1:45 pm
NOT SURE ON THE .RW5, BUT WE NEED THE .RAW FILE IN OUR PROCESS, SO IN THE DATA COLLECTOR, WE GO FILE>EXPORT- IN THESELECT TYPE OF FILE TO EXPORT WE SELECT SURVEY PRO 4.X (JOB/.RAW) FILE.
NOT EXACTLY YOUR QUESTION, BUT IT MIGHT BE SOMETHING YOU CAN WORK WITH...
Posted : March 1, 2017 1:47 pm
Loyal, post: 416405, member: 228 wrote: Not trying to be a smartass here, but what is a ".survey file?"
NEW SURVEY PRO PROPRIETARY FILE. YOU USED TO GET A .JOB AND A .RAW FILE, NOW THINGS ARE "IMPROVED"
Posted : March 1, 2017 1:48 pm
jph
 jph
(@jph)
Rankin_File, post: 416412, member: 101 wrote: NEW SURVEY PRO PROPRIETARY FILE. YOU USED TO GET A .JOB AND A .RAW FILE, NOW THINGS ARE "IMPROVED"
Yes, that's what it is. But as we both have said, you just need to take the minor extra step and export a .raw file. No big deal, really.
Posted : March 1, 2017 2:01 pm
RoadBurner
(@roadburner)
That's what I was afraid of. A .rw5 or .raw, either one would work. I don't have access to the data collector. Is there a Trimble converter?
jph
 jph
(@jph)
I don't have Trimble Office, or whatever it's called. I bet someone here does, and convert it for you.
Posted : March 1, 2017 2:05 pm
stephen-ward
(@stephen-ward)
RoadBurner, post: 416418, member: 6168 wrote: That's what I was afraid of. A .rw5 or .raw, either one would work. I don't have access to the data collector. Is there a Trimble converter?
I think the Trimble ascii generator will do the trick http://trl.trimble.com/dscgi/ds.py/Get/File-431584/ASCIIFileGenInstall.exe
Posted : March 1, 2017 2:06 pm
Jweiss
(@jweiss)
Stephen Ward, post: 416421, member: 1206 wrote: I think the Trimble ascii generator will do the trick http://trl.trimble.com/dscgi/ds.py/Get/File-431584/ASCIIFileGenInstall.exe
Yup, this is what you need.
Posted : March 1, 2017 2:25 pm
RoadBurner
(@roadburner)
Doesn't work. It will extract a .jxl file, which is identical to the .survey file (non ascii). But any other option I choose it says:
Error loading jobXML file (C:..{myjobname.survey})
Error number: -1072896760
Reason: An invalid character was found in text content.
I've tried several other .survey files and always get this error.
It doesn't list TDS .raw or .rw5 as options. Thanks for trying! : )
Posted : March 1, 2017 2:46 pm
Joe the Surveyor
(@joe-the-surveyor)
RoadBurner, post: 416403, member: 6168 wrote: Anyone know how?
Can you email me the file? I can do it for you....well at least in theory...
Posted : March 1, 2017 2:54 pm
Jweiss
(@jweiss)
RoadBurner, post: 416427, member: 6168 wrote: Doesn't work. It will extract a .jxl file, which is identical to the .survey file (non ascii). But any other option I choose it says:
I remember having issues if you didn't have Trimble Business Center installed also. I apologize I had forgotten about that. If you send to me, I'd be willing to give it a try on my machine.
Posted : March 1, 2017 2:59 pm
jimmy-cleveland
(@jimmy-cleveland)
I have Spectra Precision Survey Office, and I asked our dealer about this very thing at the KAPS conference. He said that it has to be done in the data collector. I wish there was an emulator similar to what Leica used to have for the system 1200 units.
Posted : March 1, 2017 3:01 pm
RoadBurner
(@roadburner)
Jimmy Cleveland, post: 416431, member: 91 wrote: I have Spectra Precision Survey Office, and I asked our dealer about this very thing at the KAPS conference. He said that it has to be done in the data collector. I wish there was an emulator similar to what Leica used to have for the system 1200 units.
That makes sense. Thanks for the input.
Posted : March 1, 2017 3:09 pm
stephen-ward
(@stephen-ward)
Okay, here's a link for a similar utility for Spectra Precision http://legacy.spectraprecision.com/survey-pro-downloads.asp?Nav=Collection-71637
Posted : March 1, 2017 3:32 pm
RoadBurner
(@roadburner)
Thank you Stephen. That actually reads the file. I don't know why, but no matter what format I select I can only get the points, no raw data. Maybe this .survey file is no good. It's not a huge file, we only set 3 pins and located some curb lines. I detest anything trimble.
Thanks again! 🙂
Posted : March 1, 2017 4:04 pm
Joe the Surveyor
(@joe-the-surveyor)
RoadBurner, post: 416447, member: 6168 wrote: Thank you Stephen. That actually reads the file. I don't know why, but no matter what format I select I can only get the points, no raw data. Maybe this .survey file is no good. It's not a huge file, we only set 3 pins and located some curb lines. I detest anything trimble.
Thanks again!
[/QUOTE Like I said, I may be able to convert the file if you send it to me 🙂
Posted : March 1, 2017 4:33 pm
jimmy-cleveland
(@jimmy-cleveland)
Thanks again! 🙂
Nah, the file is good. I have not figured out how to read the raw data part of the survey file. I believe our vendor is going ot have a Spectra Precision Survey Office class in April or May. I will be there with a list of questions for sure.
I have a data collector sitting on my desk beside me. If the survey file is 5.5.1 or lower, I will be glad to convert it for you. email is jcsurvey at netzero.net
Posted : March 1, 2017 5:26 pm
RoadBurner
(@roadburner)
Jimmy Cleveland, post: 416459, member: 91 wrote: Nah, the file is good. I have not figured out how to read the raw data part of the survey file. I believe our vendor is going ot have a Spectra Precision Survey Office class in April or May. I will be there with a list of questions for sure.
Thanks, Jimmy. I've no idea what version this file is. I have the coordinates, just need the raw data. Hope they get it figured out.
Posted : March 1, 2017 6:06 pm
