Civil3d Features to 3d Polylines
5 Users
leegreen
(@leegreen)
I have a DWG drawing with features lines that will only display as 3d lines with Civil3D. Carlson, Microstation, and IntelliCAD (along with all exports) display these as 2d polylines.?ÿ
How do get these features lines to export in a dumbed down DWG as 3d polylines, without doing Exploding??ÿ
Is Explode really the only method?
Posted : February 27, 2019 7:12 am
va-ls-2867
(@va-ls-2867)
exporttoautocad20xx?ÿ command in civil3d will write the feature lines to standard autocad entities
Posted : February 27, 2019 7:40 am
leegreen
(@leegreen)
Thanks. A hidden manual key-in.
The Export in the pulldown menu does a very poor job.
Posted : February 27, 2019 8:17 am
tim-v-pls
(@tim-v-pls)
Posted by: VA LS 2867
Holy moly... $1000 dollar command right there! Never knew that one - Thanks!!!
Posted : February 27, 2019 10:01 am
va-ls-2867
(@va-ls-2867)
yes, it changed from a couple years ago, used to be aeccexport... something or the other and then changed to that.?ÿ Use exporttoautocad to send dumbed down (plain autocad entities)?ÿ for cad and if they recipient needs surface info as well, export the surface to xml.?ÿ?ÿ
Posted : February 27, 2019 10:17 am
stlsurveyor
(@stlsurveyor)
Exporting as a dxf will also do the trick.
N10,000, E7,000, Z100.00
PLS - IL, MO, AR, KS, MN, KY
Posted : February 27, 2019 6:45 pm
Michael Detwiler
(@michael-detwiler)
Does this command convert survey figures to 3D poly lines, by chance?
Posted : March 1, 2019 9:36 pm
