Civil 3D Drawing transfer
8 Users
Renegade2438
(@renegade2438)
We are in the process of setting up and converting our CAD seats to C3D.
I have one seat on my computer, but not totally set up yet, just able to view drawings and make a few edits. The bulk of our work is still be done in LDD 2008.
So I open a small survey drawing the other day, make a few text edits, print the plat and sign and deliver. My CAD tech goes to open the drawing in 2008 and all the menus on his GUI are disabled and the drawing does not open all the way.
We didn't do a LDD to C3D conversion or anything like that, just opened the 2011 C3D and made some text edits and saved back to 2007 version so we could open in 2008.
Any ideas as to why this happened? Is there a setting I am missing to allow us to open drawings back up in 2008 once opened and saved of 2011 C3D?
Posted : April 23, 2012 7:00 am
John
 John
(@john)
My guess is that the newer version automatically saved in Civil 3D format, conversion or not. It seems to me that when I have dealt with two different versions of CAD, one has to explicitly "save to" the the older format, and that has been known to go sideways (not save properly in the older format) for me at least.
Posted : April 23, 2012 7:15 am
mmm184
(@mmm184)
I'm not a CAD wizard, but maybe try "exporting as" a v2008, rather than the "save as".
Posted : April 23, 2012 7:30 am
va-ls-2867
(@va-ls-2867)
You need to open the drawing in C3D and EXPORT it to Autocad 2007. Using a saveas command to save as an earlier version will still keep the C3D objects and data in the file.
spledeus
(@spledeus)
mmm, give yourself more credit. that should be the answer, the C3D is likely saving some of the objects in a later format. it's a wonderful method the autodesk folks came up with to force us to upgrade. look for the export under file and send it down to the earlier format.
Posted : April 23, 2012 7:33 am
wv-stroj
(@wv-stroj)
Some of the other CAD experts who frequent this site may know a better answer but I have never been able to simply "Save as" when trying to save a backward compatible version of my work. I currently use C3D 2010. My work around involves using the "Export as" routine in C3D, which is located right under the "Save As" on the file drop down. You'll have to give the file a new name but this new file shouldn't cause any grief in the older CAD version.
Posted : April 23, 2012 7:35 am
John
 John
(@john)
It was a couple years ago that I was playing with two different versions at home and honestly can not remember for sure if I tried the "export" or "save as".....
Posted : April 23, 2012 7:44 am
Renegade2438
(@renegade2438)
Just tried that. When I typed in export, it did not give me the option for any version of a dwg file. Only files types such as dwf, pdf etc.
Any other ideas?
Posted : April 23, 2012 8:17 am
Renegade2438
(@renegade2438)
Nevermind. Found it and that works great.
Thanks for the heads up.
Posted : April 23, 2012 8:21 am
You have just learned (probably not the first time) that AutoCAD is NOT reverse compatible. Hope that's not a surprise. You can't run two different versions successfully in the same office. Pick one or the other, get rid of the other, or be prepared for frustration and complete loss of productivity.
Posted : April 23, 2012 8:22 am
Renegade2438
(@renegade2438)
Completely understand that. Just trying to get going.
We will be doing all of our work in 2008 until such time as we have everything completley setup and are readt to go.
Posted : April 23, 2012 8:52 am
WA-ID Surveyor
(@wa-id-surveyor)
We use both LDD and Civil3d. You will be $ and time ahead if you never save back to an LDD version. Too many behind the scenes things can go wrong. Once we move a project or drawing up to Civil3d it stays in that format.
Over time we use LDD less and less and frankly don't miss it.
Posted : April 24, 2012 1:15 pm
