Carlson Survey Embedded Basic Line Command
7 Users
JonathanP
(@jonathanp)
In Autocad I can draw a line easily by just entering the distance directly. In carlson embedded the process seems a bit more cumbersome. My questions are
1. Is there a command available as easy as the normal autocad command to draw a standard line where you just line it up and enter the distance?
or
2. When carlson prompts
[Distance/Extend/Undo/]:
is it possible to set the default to Distance rather than Pick point or point numbers
to speed up the process???
Anybody have a better way?
Thanks
Posted : October 24, 2013 1:25 pm
Perry Williams
(@perry-williams)
I know that you can type this on the command line:
@100.50<s45d41'35"w
and it will draw a line 100.5 at the angle specified.
Posted : October 24, 2013 2:56 pm
cptdent
(@cptdent)
you have multiple options for line work under the COGO pull down.
Posted : October 24, 2013 7:28 pm
navaran
(@navaran)
Try extender
Posted : October 25, 2013 12:11 am
RFB
 RFB
(@rfb)
Yes.
Make a macro. I use the toolbars, create a new command;
the macro would look something like this:
LINE;d;
Translated, it issues the LINE command, followed by an ENTER (the 😉
the backslash is a PAUSE for user input (pick a point), then it issues the D option for distance, another ENTER and the rest is user input.
Posted : October 25, 2013 6:42 am
David Powell
(@david-powell)
The Plot Deed Description command works well. You just need to know your quadrants. NE=1 SE=2 SW=3 NW=4
For instance S 75d54"22" W, 222.68' would be entered as 375.5422 enter 222.68
Carlson also has and extend by distance command, EXTENDER, that has many options that may be of use to you.
Posted : October 25, 2013 7:06 am
JonathanP
(@jonathanp)
Perfect that macro is what I was looking for thanks.
Thanks to all
Posted : October 25, 2013 7:43 am
GuyGreene
(@guygreene)
the extender command in Carlson is the fastest way I calc Plats shorten lengthen all 1-9 cogo commands (yes even deflection's right and left) as well as right and left at 90° it's so fast to input the line work into a drawing; also extends curves. Is there anything that could even come close in Civil 3D?
Posted : June 3, 2015 1:44 pm
