Carlson importing Microstation DGN file
7 Users
jph
 jph
(@jph)
I did this and everything came in and looks nice.?ÿ But the points are just mtext.?ÿ Is there a way to convert the points to Carlson, or at least a txt file that I can then bring into my dwg?
Posted : November 21, 2018 8:06 am
mvanhank222
(@mvanhank222)
Update to 2019 it has native.DGN?ÿ
Posted : November 21, 2018 9:07 am
jph
 jph
(@jph)
Is that for the embedded ACAD or ICAD??ÿ Or both?
Also, does it read the points?
Posted : November 21, 2018 11:26 am
leegreen
(@leegreen)
No, Microstation does NOT write any data links to the points. You need the operator in Microstation to send you a text file that can import into Carlson.
Posted : November 21, 2018 11:47 am
jph
 jph
(@jph)
Thanks
So basically, you can't read the points, but the benefit is that you can do the drafting in Carlson and save the deliverable to a dgn.?ÿ
You just can't talk back and forth with the points.
Posted : November 21, 2018 11:54 am
cptdent
(@cptdent)
While I am a Carlson Reseller, please let me give you this little piece of advice that I have learned over the last 50 yars as a Cadmonkey: NEVER, NEVER buy the initial release of any software package. Unless you just get off on being a Beta tester.
Posted : November 21, 2018 12:36 pm
cptdent
(@cptdent)
cptdent
(@cptdent)
cptdent
(@cptdent)
leegreen
(@leegreen)
Posted by: JPH
Thanks
That is correct. Microstation is only a CAD engine or the media in which you draw on to.
?ÿInRoads is the cogo app that runs on top of Mstation, much like Carlson runs on top of Acad or IntelliCAD. So without InRoads the points are only text in the cad file.
Posted : November 21, 2018 12:40 pm
Rgp3261
(@rgp3261)
Try looking at the import Eagle Point Nodes routine in Carlson. That routine will search for the graphics that include a point node with associated text for PT number, description and elevation...
Posted : November 22, 2018 10:57 am
jawja
(@jawja)
Actually, it is not ENTIRELY true that points do not reside in the DGN.
In the past, inroads or Geopak were the point handlers with planimetrics (no smart data) being in the DGN.?ÿ However now, if the dgn was an openroads file, it is native dgn and all in the dgn.?ÿ Much like Acad through LDD points were separate but C3D put in the dwg.
Posted : November 24, 2018 5:00 am
Joan Davis
(@joan-davis)
I just tested out one DGN file and I did extract points from it. Can you send me the file?
Posted : November 28, 2018 2:06 pm
jph
 jph
(@jph)
How did you extract them, using Carlson or something else?
Posted : November 29, 2018 9:39 am
Joan Davis
(@joan-davis)
Yes, using Carlson 2018 w/icad. I will type up directions later.
Posted : November 29, 2018 6:14 pm
Joan Davis
(@joan-davis)
JPH,
This is what I did....keep in mind I only have one dgn file for this test that clearly had points in it.
In the command line type DGNio, navigate the dialog box converting it to dwg. Open the dwg. In my case the point numbers and descriptions were in a block. I exploded the block. Type?ÿcfuupdatecrd in the command line, name your crd file and select all. ?ÿ
If you have problems I can test your file out on my end.?ÿ
Posted : November 30, 2018 8:05 am
