Carlson Contour Multiple Sites in Same Drawing
I have drawn 2D & 3D shrink wrap boundaries around these multiple sites in the same drawing:
What settings do I need to employ in order to draw contours within these multiple sites?
And thusly, and therefore avoid this mess?
Thank you.
Posted : March 28, 2020 4:13 pm
Mark Indzeris
(@mark-indzeris)
Check use inclusion/ exclusion areas and when prompted select the closed polylines for inclusion.?ÿ
If it is still problematic, create a separate surface for each area.
Posted : March 28, 2020 4:48 pm
@mark-indzeris
That worked like a charm!
Thank you.
Posted : March 28, 2020 6:40 pm
jph
 jph
(@jph)
@brad-ott
Depending on the site, sometimes I'll create different surfaces within the same dwg, and use the surface prefix for the layers - contours, tin lines, etc.  This is usually when topos are done at different times, but all within the same project.  That way you're not re-contouring areas whenever you add more topo.
Posted : March 31, 2020 6:37 am
@jph that is a great tip!
Posted : March 31, 2020 1:13 pm
