carlson closure question 2008n stand alone
5 Users
Dane Mince
(@danemince)
I have a deed description that does not close 2' x2. I want to create a carlson closure that demonstrates that the raw data closure without forcing a closure or manipulation any suggestion. Most closure routines are designed to prove perfections and not show the raw data...suggestions welcomed
Posted : September 23, 2015 8:04 pm
jimmy-cleveland
(@jimmy-cleveland)
Can you do an inverse by area, and show that as your closure? It will show an error of closure, closing bearing, etc.
Posted : September 24, 2015 2:04 am
I don't follow your question.
A deed does not close, OK, but what does raw data have to do with It?
Posted : September 24, 2015 4:47 am
foggyidea
(@foggyidea)
When you enter it through "Enter Deed Description" it gives you a raw closure when you hit end, doesn't it?
Posted : September 24, 2015 6:05 am
Dane Mince
(@danemince)
THANKS FOR THE HELP Next time I will consult with Paul in PA prior to posting. I was trying to distinguish between entering data directly from the deed and any manipulation that might be used , whence raw.....
There are quite a few features in Carlson that I rarely use.
Posted : September 24, 2015 10:11 am
cptdent
(@cptdent)
If you are checking out a copy of the deed, run the "Enter Deed Description" function as suggested above. Then, to get down to the real nitty-gritty, run the Map Check routine under Survey.
Posted : September 24, 2015 10:40 am
