Has anyone worked with using ATTRIBUTES in Carlson Cad. To also provide field to finish. An example would be to have a single code for a found property corner. So IRF in the field I would have my field codes Trimble prompt the crew to the. Add attributes some from a pull down list or type in. Attribute 1 what is it pipe stone rebar etc. then another attribute that stated size 1” 5/8 4x4 for say a stone. Then condition. Is it bent disturbed etc. also add a photo. I have a work around for photos but how do I get Carlson cad field to finish to recognize those attributes and assign the txt like bent rod and other attributes. Also how best to get that data into Carlson points file or shape etc. I do all our adjustments qa/qc in TBC as we run Trimble gear then export the good points files. I am open to any other options
No experience, but possibly you want to explore "GIS/Note/Point Attribute Labels".
@peter-lothian gotcha. Will give that a go. Thanks.
