I thought there was a way to scale all text in a drawing without moving its location. Is this possible with multi line text that is not mtext.
MAG-EYE, post: 429393, member: 8763 wrote: I thought there was a way to scale all text in a drawing without moving its location. Is this possible with multi line text that is not mtext.
Not sure about ICAD, but in AutoCad you could just change the size of the text in the text style.
Settings>Rescale drawing
select similar and adjust text size in properties?
Annotative?
No not annotative.
I think Totalsurv is onto what i was thinking of. Although as i thought if its multi line standard text not mtext the spacing between lines is an issue. Maybe this is a good reason to start labeling with mtext.
Thanks Totalsurv, I just need to convert all my multi line text to mtext and rescale drawing under settings is just what i needed.
Thaks guys for your input.
Edit>Text>Text Reduce/Enlarge
