Did anyone try their service? It's free. I think I uploaded 2x and have not gotten any results from them. Anyone got a response? I wanted to try it because it says it accepts Galileo and Beidou satellites.
I use it frequently. Never had an issue with not getting a response back. If something was wrong with my file I believe it either sent me an email or told me right away.?ÿ
Rather than use the RTX upload page ( https://www.trimblertx.com/UploadForm.aspx) , which does not allow one to change the antenna or HI, I prefer to use
https://surveytools.trimbleaccess.com/gnssprocessor
it reads the antenna type and HI in the file and allows you to edit those values.?ÿ?ÿ
It says it uses Beidou but I have found that it actually does not. I am not sure why they keep that up there. Can't complain about a good free service, though.?ÿ
They also say that the real time RTX (subscription) also uses Beidou, but last time I used it it did not. I keep one receiver under subscription, it has come in very handy in areas where there was no cell service or no RTN available?ÿ
I have used it quite a bit as a check on OPUS solutions, and as a standalone when the OPUS site was down or having problems. I like being able to submit directly from Business Center if I want. Solid service, especially for free, and the format is easier to read than OPUS. (That being said, I still prefer OPUS extended reports.)
It was working for us as of last week. They still haven't fixed the text of the automated email, which refers to ITRF08 rather than ITRF2014. The actual report is still in ITRF2014, though...
Thanks for the new links. How large are your files? My obs file is 120mb and there is no confirmation page that the file was uploaded properly unlike in the OPUS/AUSPOS pages. So not sure if size might be the cause.
No luck in getting a solution. Error in uploading file.?ÿ
I only use Trimble RTX post processing, not OPUS. One of these decades NGS might reprogram to process other constellations. And I don't use the Survey Tools.. website because it may only use GLONASS and not also Galileo and Beidou.?ÿ The post process website also allows you to zip up multiple static files, provided there's not a large gap in time between the observation times.
If you don't a return email in a few minutes, check your junk/spam folder.
Check your spam folder.?ÿ Even if it can't process it usually send a message saying so.?ÿ I used to use it as a check against OPUS and quickly reversed my thinking.?ÿ I use OPUS to check RTX then just archive the OPUS data and don't really use it.?ÿ I've found RTX solutions to check against my robotic data much more precisely than OPUS.?ÿ I'm not saying RTX is more accurate than OPUS, but it does seem to be more precise (and robust - it will definitely give me centimetre results more often in areas OPUS fails).
I use it with TBC, I check a box during upload and it processes the file.
It has always worked unless the file is too short, say a 2 minute PPK file.?ÿ
Sometimes even a very short remote session will process.?ÿ
