Trimble Alloy-NTrip...
Trimble Alloy-NTrip problems
1 Users
I have a Trimble Alloy that I use as a base, sometimes in a fixed location with internet access but sometimes in the field with a cell modem for access to the NTrip caster on board. It has always worked well.
Last week I decided to try it using an external radio, a Trimmark III to broadcast RTK corrections. Seemed to work OK, except I had it set for 4800 baud over the air rather than 9600, so it did not send all constellations over the air (rover was a new R10-2).?ÿ
After that, it now only transmits empty NTrip packets over the network. I tried resetting it, re-installing the firmware (5.43), but nothing seems to help. As a test I put the R10-2 side by side, and had both of them configured to send RTCM3.2 to SNIP running on my desktop (internal network). Here are the packets the R10-2 was sending out:
And the Alloy:?ÿ
after about 7 minutes, here is a comparison of the data flows (TS is the alloy)
As can be seen the R10-2 sent 800KB of data and the Alloy only 7 KB.?ÿ
The reference position is accurate on ITRF to better than 1 cm in all three dimensions, so that is not an issue. I also tried CMRx, but same issue.?ÿ
Has anyone else ever tried to send corrections out the serial port to a radio from the Alloy? It may have nothing at all to do with the fact that I hooked the TM3 up, but the last time I used it before that it worked fine. Maybe just a coincidence...
I didn't try the radio again but maybe I will test that tonight
I need to take it to the dealer but just wanted to see if anyone else has this problem.?ÿ
It does seem to be tracking OK, here is tracking summary from the header of a rinex 3 file for 24 hours...
C 10 C1X C2I C5X C6I C7I L1X L2I L5X L6I L7I SYS / # / OBS TYPES
R 10 C1C C1P C2C C2P C3X L1C L1P L2C L2P L3X SYS / # / OBS TYPES
G 8 C1C C2W C2X C5X L1C L2W L2X L5X SYS / # / OBS TYPES
E 10 C1X C5X C6X C7X C8X L1X L5X L6X L7X L8X SYS / # / OBS TYPES
S 4 C1C C5I L1C L5I SYS / # / OBS TYPES
101 # OF SATELLITES
C11 0 1729 0 1729 1729 0 1729 0 1729PRN / # OF OBS
1729 PRN / # OF OBS
C12 0 1407 0 1407 1407 0 1407 0 1407PRN / # OF OBS
1407 PRN / # OF OBS
C14 0 1456 0 1455 1451 0 1456 0 1455PRN / # OF OBS
1451 PRN / # OF OBS
C19 1685 1685 1685 1685 0 1685 1685 1685 1685PRN / # OF OBS
0 PRN / # OF OBS
C20 1835 1835 1835 1835 0 1835 1835 1835 1835PRN / # OF OBS
0 PRN / # OF OBS
C21 1518 1527 1526 1526 0 1518 1527 1526 1526PRN / # OF OBS
0 PRN / # OF OBS
C22 1379 1384 1381 1378 0 1379 1384 1381 1378PRN / # OF OBS
0 PRN / # OF OBS
C23 2093 2097 2088 2095 0 2093 2097 2088 2095PRN / # OF OBS
0 PRN / # OF OBS
C24 1157 1157 1157 1157 0 1157 1157 1157 1157PRN / # OF OBS
0 PRN / # OF OBS
C25 1832 1832 1832 1832 0 1832 1832 1832 1832PRN / # OF OBS
0 PRN / # OF OBS
C26 1176 1176 1176 1176 0 1176 1176 1176 1176PRN / # OF OBS
0 PRN / # OF OBS
C27 1627 1627 1627 1627 0 1627 1627 1627 1627PRN / # OF OBS
0 PRN / # OF OBS
C28 1820 1820 1820 1820 0 1820 1820 1820 1820PRN / # OF OBS
0 PRN / # OF OBS
C29 1567 1573 1572 1572 0 1567 1573 1572 1572PRN / # OF OBS
0 PRN / # OF OBS
C30 1973 1979 1979 1976 0 1973 1979 1979 1976PRN / # OF OBS
0 PRN / # OF OBS
C32 1777 1777 1777 1777 0 1777 1777 1777 1777PRN / # OF OBS
0 PRN / # OF OBS
C33 1579 1579 1579 1579 0 1579 1579 1579 1579PRN / # OF OBS
0 PRN / # OF OBS
C34 1623 1623 1623 1623 0 1623 1623 1623 1623PRN / # OF OBS
0 PRN / # OF OBS
C35 1389 1398 1395 1397 0 1389 1397 1395 1396PRN / # OF OBS
0 PRN / # OF OBS
C36 1620 1620 1620 1620 0 1620 1620 1620 1620PRN / # OF OBS
0 PRN / # OF OBS
C37 2149 2151 2151 2151 0 2149 2151 2151 2151PRN / # OF OBS
0 PRN / # OF OBS
C57 0 1108 0 1105 0 0 1108 0 1105PRN / # OF OBS
0 PRN / # OF OBS
E01 1229 1229 1229 1229 1229 1229 1229 1229 1229PRN / # OF OBS
1229 PRN / # OF OBS
E02 2007 2007 2007 2007 2007 2007 2007 2007 2007PRN / # OF OBS
2007 PRN / # OF OBS
E03 1823 1823 1823 1823 1823 1823 1823 1823 1823PRN / # OF OBS
1823 PRN / # OF OBS
E04 1166 1166 1163 1160 1166 1166 1166 1163 1160PRN / # OF OBS
1166 PRN / # OF OBS
E05 1049 1049 1049 1049 1049 1049 1049 1049 1049PRN / # OF OBS
1049 PRN / # OF OBS
E07 2053 2042 2048 2038 2049 2053 2042 2048 2038PRN / # OF OBS
2049 PRN / # OF OBS
E08 2377 2377 2377 2377 2377 2377 2377 2377 2377PRN / # OF OBS
2377 PRN / # OF OBS
E09 557 557 556 543 557 557 557 556 543PRN / # OF OBS
557 PRN / # OF OBS
E11 1096 1096 1096 1096 1096 1096 1096 1096 1096PRN / # OF OBS
1096 PRN / # OF OBS
E12 1164 1164 1164 1164 1164 1164 1164 1164 1164PRN / # OF OBS
1164 PRN / # OF OBS
E13 2270 2270 2270 2270 2270 2270 2270 2270 2270PRN / # OF OBS
2270 PRN / # OF OBS
E14 1355 1355 1355 1355 1355 1355 1355 1355 1355PRN / # OF OBS
1355 PRN / # OF OBS
E15 2103 2103 2103 2103 2103 2103 2103 2103 2103PRN / # OF OBS
2103 PRN / # OF OBS
E18 1185 1181 1185 1180 1185 1184 1181 1184 1180PRN / # OF OBS
1185 PRN / # OF OBS
E19 1950 1950 1950 1950 1950 1950 1950 1950 1950PRN / # OF OBS
1950 PRN / # OF OBS
E21 2513 2513 2513 2513 2513 2513 2513 2513 2513PRN / # OF OBS
2513 PRN / # OF OBS
E24 504 504 504 504 504 504 504 504 504PRN / # OF OBS
504 PRN / # OF OBS
E25 1203 1203 1203 1203 1203 1203 1203 1203 1203PRN / # OF OBS
1203 PRN / # OF OBS
E26 1762 1762 1762 1762 1762 1762 1762 1762 1762PRN / # OF OBS
1762 PRN / # OF OBS
E27 2601 2592 2601 2597 2601 2600 2592 2600 2597PRN / # OF OBS
2601 PRN / # OF OBS
E30 2492 2492 2492 2492 2492 2492 2492 2492 2492PRN / # OF OBS
2492 PRN / # OF OBS
E31 675 675 675 675 675 675 675 675 675PRN / # OF OBS
675 PRN / # OF OBS
E33 1274 1267 1269 1262 1266 1274 1267 1269 1262PRN / # OF OBS
1266 PRN / # OF OBS
E36 1593 1593 1593 1593 1593 1593 1593 1593 1593PRN / # OF OBS
1593 PRN / # OF OBS
G01 1686 0 1684 1686 1673 0 1684 1686 PRN / # OF OBS
G02 1689 1688 0 0 1688 1688 0 0 PRN / # OF OBS
G03 1849 0 1848 1848 1849 0 1848 1848 PRN / # OF OBS
G04 1044 0 1040 1035 1036 0 1040 1035 PRN / # OF OBS
G05 1498 0 1498 0 1498 0 1498 0 PRN / # OF OBS
G06 1567 0 1567 1567 1567 0 1567 1567 PRN / # OF OBS
G07 1417 0 1417 0 1417 0 1417 0 PRN / # OF OBS
G08 1365 0 1365 1365 1365 0 1365 1365 PRN / # OF OBS
G09 1747 0 1746 1747 1744 0 1746 1747 PRN / # OF OBS
G10 1506 0 1506 1506 1506 0 1506 1506 PRN / # OF OBS
G11 1314 1313 0 0 1313 1313 0 0 PRN / # OF OBS
G12 1814 0 1814 0 1807 0 1814 0 PRN / # OF OBS
G13 1653 1558 0 0 1633 1553 0 0 PRN / # OF OBS
G14 1643 1642 0 0 1643 1642 0 0 PRN / # OF OBS
G15 1385 0 1385 0 1385 0 1385 0 PRN / # OF OBS
G16 1430 1429 0 0 1430 1429 0 0 PRN / # OF OBS
G17 1674 0 1674 0 1674 0 1674 0 PRN / # OF OBS
G19 1616 1615 0 0 1616 1615 0 0 PRN / # OF OBS
G20 1558 1557 0 0 1557 1557 0 0 PRN / # OF OBS
G21 1337 1329 0 0 1333 1328 0 0 PRN / # OF OBS
G22 1836 1820 0 0 1831 1819 0 0 PRN / # OF OBS
G23 1556 1512 0 0 1551 1509 0 0 PRN / # OF OBS
G24 1655 0 1649 1651 1648 0 1649 1651 PRN / # OF OBS
G25 1816 0 1816 1816 1805 0 1816 1816 PRN / # OF OBS
G26 1399 0 1399 1399 1399 0 1399 1399 PRN / # OF OBS
G27 1645 0 1643 1640 1635 0 1643 1640 PRN / # OF OBS
G28 1579 1579 0 0 1579 1579 0 0 PRN / # OF OBS
G29 1683 0 1667 0 1679 0 1667 0 PRN / # OF OBS
G30 1435 0 1422 1434 1435 0 1422 1434 PRN / # OF OBS
G31 1568 0 1568 0 1568 0 1568 0 PRN / # OF OBS
G32 1646 0 1646 1646 1646 0 1646 1646 PRN / # OF OBS
R01 1455 1455 1455 1455 0 1455 1455 1455 1455PRN / # OF OBS
0 PRN / # OF OBS
R02 1478 1478 1478 1478 0 1478 1477 1477 1478PRN / # OF OBS
0 PRN / # OF OBS
R03 1524 1524 1524 1524 0 1524 1524 1524 1524PRN / # OF OBS
0 PRN / # OF OBS
R05 2100 2097 2095 2095 0 2099 2097 2094 2094PRN / # OF OBS
0 PRN / # OF OBS
R06 1834 1834 0 0 0 1834 1834 0 0PRN / # OF OBS
0 PRN / # OF OBS
R07 1300 1297 1296 1295 0 1300 1297 1296 1295PRN / # OF OBS
0 PRN / # OF OBS
R08 1291 1290 1290 1291 0 1291 1290 1290 1290PRN / # OF OBS
0 PRN / # OF OBS
R09 1375 1375 1375 1375 639 1375 1375 1375 1375PRN / # OF OBS
638 PRN / # OF OBS
R10 1600 1600 0 0 0 1600 1600 0 0PRN / # OF OBS
0 PRN / # OF OBS
R11 1661 1660 1631 1649 0 1660 1658 1630 1645PRN / # OF OBS
0 PRN / # OF OBS
R12 1529 1525 1527 1527 0 1529 1525 1527 1527PRN / # OF OBS
0 PRN / # OF OBS
R13 1145 1145 1145 1145 0 1145 1145 1145 1145PRN / # OF OBS
0 PRN / # OF OBS
R14 1856 1856 1856 1856 0 1856 1856 1856 1856PRN / # OF OBS
0 PRN / # OF OBS
R15 1974 1974 1974 1974 0 1974 1974 1974 1974PRN / # OF OBS
0 PRN / # OF OBS
R16 1729 1729 1728 1729 0 1729 1729 1728 1729PRN / # OF OBS
0 PRN / # OF OBS
R17 2072 2070 2063 2068 0 2072 2070 2062 2068PRN / # OF OBS
0 PRN / # OF OBS
R18 1819 1819 1819 1819 0 1819 1819 1819 1819PRN / # OF OBS
0 PRN / # OF OBS
R19 1172 1171 1171 1171 0 1171 1171 1171 1170PRN / # OF OBS
0 PRN / # OF OBS
R20 1461 1461 1461 1461 0 1461 1461 1461 1461PRN / # OF OBS
0 PRN / # OF OBS
R21 1481 1481 1481 1481 1481 1481 1481 1481 1481PRN / # OF OBS
1481 PRN / # OF OBS
R22 1316 1316 1315 1315 0 1316 1316 1315 1315PRN / # OF OBS
0 PRN / # OF OBS
R23 1646 1645 1627 1642 0 1646 1645 1627 1642PRN / # OF OBS
0 PRN / # OF OBS
S31 5760 5760 5760 5760 PRN / # OF OBS
S38 5760 5760 5760 5760 PRN / # OF OBS
Posted : December 17, 2019 11:52 am
