The upload page for RTX says that it uses Beidou...
However, when I submit a file that has Beidou it does not use it...
I am pretty sure I have seen Beidou used by RTX in the past. I also believe that the higher numbered Beidou satellites are not being used in RTK solutions...is there a connection here? Did something in Beidou change that affects the usability??ÿ
when I use teqc to convert to rinex (with no special flags) I don't get an Beidou satellites, and there is a message flashed on the screen...
Not sure if there is a switch that will enable it to use Beidou...or maybe version 2 of Rinex cannot use them? When I use the trimble convert-to-rinex utility it does put the Beidou data in to rinex V3, but SV numbers above 14 have more types of data...
