Leica infinity - ba...
Leica infinity - baseline processing
moses.rbn
(@moses-rbn)
Hey experts,
I have created my base lines and process them. I consider all the available and possible baselines, processed them and stored them with two fixed control points. But, when i want to perform a 3d/2d adjustments it keeps telling me "Not enough Observation available".
what might cause this error??ÿ
Posted : August 5, 2021 10:34 pm
moses.rbn
(@moses-rbn)
Please some one help me.?ÿ
How do you guys post process your GPS baselines? Can you solve my problem with Leica infinity?
Posted : August 6, 2021 6:53 pm
shelby-h-griggs-pls
(@shelby-h-griggs-pls)
I haven't had the issue. Did you set at least one station as control? In the pervious LGO, you didn't have too, just throwing it out there, both software use the same basic Move3 adjustment kernell.
SHG
Posted : August 22, 2021 2:28 pm
moses.rbn
(@moses-rbn)
Hey,?ÿ
Yes I had 3 points fully constrained. I changed the software to TBC then it worked perfectly with an amazing results. I reckon Leica is not good. It has lots of problems.?ÿ
Posted : August 22, 2021 11:04 pm
john-putnam
(@john-putnam)
In the 'Adjustment' tab, are the coordinates set to WGS84??ÿ GNSS observations can only be adjusted in WGS84.
Posted : August 23, 2021 8:38 am
summerprophet
(@summerprophet)
@moses-rbn?ÿ
Leica makes some excellent products. Captivate is not one of them.
Posted : August 28, 2021 10:17 pm
moses.rbn
(@moses-rbn)
@john-putnam I just tried that out. It is not working again. It gives me the same error. Believe me, Infinity is the worst commercial software.
Posted : August 29, 2021 1:50 am
john-putnam
(@john-putnam)
Have you tried an unconstrained adjustment or just holding one control point fixed??ÿ Not saying this is a solution but it would let you know if Infinity adjustment is working.
I'm guessing it is a simple setting somewhere.?ÿ You could always call Leica tech support, they are actually pretty helpful.
Posted : August 29, 2021 8:05 am
