Newer used truck
30 Users
I may be deciding that it might be time to replace my 23-year old 1998 GMC Sierra with a newer 5-10-year old model.
This looks like a very helpful website (as well as cars.com):
carcomplaints.com
(I wish I could copy and paste websites from my iPhone like I used to be able to.)
Posted : 14/07/2021 12:57 pm
(@richard-imrie)
Toyota should be your friend.
Posted : 14/07/2021 1:18 pm
(@jitterboogie)
@richard-imrie?ÿ
IMG 20210706 211800213
Miles ...
Synthetic oil is the way.....
Posted : 14/07/2021 1:40 pm
(@drew-r)
I believe I said this yesterday but... Toyota. Tundra if you need the space, Tacoma if you get into tight off-road conditions. Having run many full-size pickups through many crews, I can say there is no comparison.?ÿ
Favor you must do yourself. Yota
Posted : 14/07/2021 1:50 pm
Posted by: @drew-r
YoDa
There, I fixed it for you...
Posted : 14/07/2021 3:23 pm
(@dmyhill)
@drew-r?ÿ
I liked the Tundra as well.
Posted : 14/07/2021 3:24 pm
nope nope nopeƒ??- if their own design team writes TURD across the product line, who am I to disagreeƒ??.
Posted : 14/07/2021 3:27 pm
GMC 2500 is comparable to which Toyota model for hauling my heavy survey box full of gear and towing my Gator XUV on a trailer?
Posted : 14/07/2021 3:49 pm
I like em, but Toyota's are too small for my work.
Posted : 14/07/2021 4:04 pm
(@stlsurveyor)
@brad-ott Tundra with the 5.7 V8 should do the trick. Used Tundras are hard to find, just like used Tacomas. FWIW, I have a 4-Runner and love it, solid.
Posted : 14/07/2021 4:26 pm
Not my work rig but Iƒ??ll vouch for the Tundra. I have a 2012 crew cab with a full bed, 5.7 Liter and it is a really well made truck. The rear air suspension can be adjusted for the load and has zero trouble pulling a camper up the biggest hills. Check the weight ratings to see if the suspension is up to what you want to carry.?ÿ
Posted : 14/07/2021 4:33 pm
Posted by: @williwaw
How? ?ÿMy mechanic says:
Maybe. My truck is 27years old and doing fine. However considering how much weight you have in the back of the truck plus the Gator maybe you need a 2500 truck instead of a 1500.
Posted : 14/07/2021 4:59 pm
@brad-ott?ÿ
Base Toyota Tundra models feature a standard 310-horsepower 4.6-liter V-8 that is capable of towing 6,800 pounds and has a maximum payload of 1,585 pounds. If you are looking for even more power, the 381-horsepower 5.7-liter V-8 possesses a maximum towing capacity of 10,500 pounds and maximum payload of 2,060 pounds.Feb 9, 2016
Your mechanic is right. You want a 3/4 ton over a 1/2 ton (1500 vs 2500) if you have considerable weight to haul.
Posted : 14/07/2021 5:17 pm
@williwaw thanks, buddy.
Posted : 14/07/2021 5:29 pm
(@stlsurveyor)
@brad-ott You should take a look at these:
Posted : 14/07/2021 5:40 pm
(@350rocketmike)
Posted by: @brad-ott
carcomplaints.com
I recommend either a 99-07 GM truck or a Toyota (be careful of frame rust if they use salt where you live). Gm really dropped the quality of the new body style 2007+. If you're currently running a 98 a 2005-07ish should last a long time. Less maintenance as they don't have the distributor cap and rotor on the LS style V8. Also the transmissions seem more reliable on the mid 2000 models.?ÿ
Posted : 14/07/2021 6:42 pm
(@350rocketmike)
@brad-ott?ÿ
My 05 Silverado 1500 hailed a packed enclosed trailer plus packed box and cab for moving to our new house this weekend. It did fine but if you were towing that weight every day a 2500 would be preferable which Toyota doesn't have.?ÿ
I wouldn't recommend a gm 2500 2007+ though. Or a ford or dodge.?ÿ
Posted : 14/07/2021 6:52 pm
(@fairbanksls)
Low mileage 7.3 Ford turbo diesel or a Dodge Cummins turbo diesel will pull anything you want and get better mileage than a gas engine towing or hauling a heavy load.?ÿ Torque is what gives you towing power.
Run synthetic oil and it'll outlast a To ota.?ÿ I think one reason Toyota's last longer is people who buy them maintain them better.
Posted : 14/07/2021 7:56 pm
(@warrenward)
Has anyone tried replacing their old engine? Instead of a newer used truck?
Posted : 15/07/2021 12:07 am
Page 1 / 6
