Definition of Responsible Charge
12 Users
field-dog
(@field-dog)
Concerning licensure in Florida, how is responsible charge defined if you work in the office?
Posted : June 12, 2019 6:15 am
field-dog
(@field-dog)
The reason I'm asking is, next year I'm going for an office position as a CAD tech. It isn't a senior CAD tech position, so I won't be in responsible of drafting a project.
Posted : June 12, 2019 9:07 am
just-a-surveyor
(@just-a-surveyor)
I always learned that if you got a azz chewing then you were responsible.
Posted : June 12, 2019 9:51 am
(6)ƒ?ŸThe term ƒ??responsible chargeƒ? means direct control and personal supervision of surveying and mapping work, but does not include experience as a chainperson, rodperson, instrumentperson, ordinary draftsperson, digitizer, scriber, photo lab technician, ordinary stereo plotter operator, aerial photo pilot, photo interpreter, and other positions of routine work.
Posted : June 12, 2019 10:04 am
mike-marks
(@mike-marks)
I've seen responsible charge in practice range from "direct control and personal supervision?ÿ .?ÿ .?ÿ . " as above, to an LS who comes to the office every week or three, reviews maps ready for filing/recordation, and stamps them for $150 a pop.
Posted : June 12, 2019 10:46 am
field-dog
(@field-dog)
That's a pretty explicit answer! Basically I'll be in the same situation I'm in now.
Posted : June 12, 2019 11:13 am
Responsible Charge is a situation that you have taken the field data and done everything from research, computations and creating a drawing and property descriptions and whatever reports necessary to complete the survey product by yourself.
In other words, you are in complete control of what is done to finalize the survey and have it ready for the client, short of signing and stamping the document.
good luck
Posted : June 12, 2019 2:21 pm
BStrand
(@bstrand)
Member P&R
Responsible charge is the guy who stamps things.?ÿ Because if shite goes sideways nobody is coming after your cad tech or party chief or equipment dealer or anyone else.
Posted : June 12, 2019 7:41 pm
"472.000(6), Florida Statutes?ÿThe term "responsible charge" means direct control and personal supervision of surveying and mapping work, but does not include experience as chainperson, rodperson, instrument person, draftsperson, digitizer, scriber, photo lab technician, ordinary stereo plotter operator, aerial photo pilot, photo interpretor or or other positions of routine work."?ÿ
Full text.
Posted : June 12, 2019 9:32 pm
jkinak
(@jkinak)
Not Necessarily.
You can be in responsible charge without being licensed - an unlicensed person operating quasi-autonomously performing qualifying work under the watchful eye of the licensee stamping the work is also in responsible charge - this is how you get part of the experience necessary to qualify to sit for the exam. See the FL def Paul in PA posted below.
Posted : June 13, 2019 12:13 am
You don't have to be that specific on the FL. surveyors application to sit for the test. For example if you become a CAD tech you are in responsible charge of whatever you are working on. Topo, boundary, etc. Florida Statutes are inconclusive with respect to "responsible charge". Although a senior tech may check your work, technically you are in responsible charge of what was produced. Hope this helps. ?????ÿ
Posted : June 13, 2019 6:42 am
rover83
(@rover83)
This.
The term gets thrown around pretty loosely. Responsible charge for a project refers to the licensee who seals and signs the project documents and who is ultimately responsible/liable for the information shown and the project deliverables.
But in regards to obtaining experience toward licensure, the general standard is whether someone is making judgment calls and independent decisions in the course of their daily work, without someone constantly looking over their shoulder. More than mindless drafting or staking out, where the responsible LS will review and discuss the decisions made but trust you enough to not have to check every single step of the way.
Would be nice to differentiate the two a little more easily, it seems to cause a lot of confusion.
Also: I have run across a handful of folks who seem to think one cannot accrue responsible charge prior to obtaining their LSIT or passing the FS. I have yet to run across a statute that specifically requires this in the dozen or so states I have researched - although I suppose there may be one out there. If someone is denying you responsible charge that meets the above standard simply because you have not obtained your LSIT, it's time to jump ship...
Posted : June 13, 2019 9:10 am
As I read PA's new law, (for many the old law is still in effect) experience prior to being an LSIT is wiped out when one becomes an LSIT. It is probable that one could request a hearing and argue the point, but I chose to be very careful in applying under the old law.
Posted : June 13, 2019 10:52 am
field-dog
(@field-dog)
Thanks! I feel better now about making a move into the office.
Posted : June 13, 2019 12:24 pm
field-dog
(@field-dog)
In PA, can you be a LSIT while completing your 4-year degree or do you have to have earned your 4-year degree first?
Posted : June 13, 2019 12:32 pm
steven-metelsky
(@steven-metelsky)
Person in Responsible Charge is the licensed professional who receives the letters from the state board and signs and seals all documents to be issued.
As regards an applicant: you need to log your time which is necessary to fill out your "Report of Professional Experience."
The definition for what you need as a person looking to be licensed is outlined on the application.
Some states start the timer from when you get a job. Some states start the timer after your LSIT. Some states do the latter but will consider the former depending on experience.
Bottom line: a state will not issue a license to someone heavy on CAD documentation, but no field work. Balance your time, keep track of your time. Document any major project you worked on and your duties within it. I used a standard field book.
Posted : June 15, 2019 1:52 pm
jkinak
(@jkinak)
"Bottom line: a state will not issue a license to someone heavy on CAD documentation, but no field work."
Not true.
Alaska is a state and in Alaska field work is NOT a requirement to get licensed. Our definition of land surveying is broad and a person could develop boundaries using GIS software from data acquired by others their entire career - this person would be practicing land surveying per our statutes/regs and IF the work they did was under the direct supervision of a licensed land surveyor (and 3 of those years must be in responsible charge - see 12 AAC 36.065. ELIGIBILITY FOR PROFESSIONAL LAND SURVEYOR EXAMINATION), that time would count toward licensure. There is no field requirement.
Photogrammetrists are another group of land surveyors who are unlikely to ever get (or need) field experience.
I haven't researched other statutes/regs but I'd be surprised if there weren't quite a few jurisdictions that don't have a field work  requirement.
Posted : June 15, 2019 2:19 pm
aliquot
(@aliquot)
Posted by: JKinAK
Not true.
I haven't researched other statutes/regs but I'd be surprised if there weren't quite a few jurisdictions that don't have a field work?ÿ requirement.
I haven't read the Alaska regulations in a while. I don't remember the need to be a supervisor to count experience as responsible charge. Is that new? That could make life difficult for some.
Posted : June 15, 2019 5:30 pm
aliquot
(@aliquot)
"Does not include experience as a draftperson"
Will your new job include decision making exceeding that required from a draftperson? If not it won't count.
Posted : June 15, 2019 5:34 pm
jkinak
(@jkinak)
I don't think this reg language has changed in quite some time. The language in the regs is:
“Responsible charge of professional land surveying (P.L.S.)” means work as a supervisor under the responsible control of a land surveyor registered in the United States, and working in the “practice of land surveying” as described in AS 08.48.341.
Supervisor means overseer of work (or people doing that work) but does not mandate that the individual be supervising staff.
Posted : June 15, 2019 8:06 pm
