Zeiss Elta S20
(@mattsib79)
So I set up my Zeiss and have my geo-radio on hooked up to my hp48 running smi. The geo radio has a red light that shows the power is on. It has separate lights on the side and only green power light is on. I turn on the instrument and it tries to connect to the radio but nothing.
Any suggestions?
Thank you in advance!
Matt
Posted : February 12, 2013 5:46 pm
(@survey-or)
Matt,
Does the instrument have SMI installed on it? It should be one of the options to select during the boot process. Most of these did come with SMI as they were sold as part of an SMI package but you may have one of the ones that came from a different supplier. There is not a lot of help available out there regarding this instrument,
if you send me your email I will send along some operating instructions.The email link in my profile should work.
Glenn
Posted : February 13, 2013 6:57 am
As I recall, you need an SMI card on the Zeiss. I only use my S10 now as a servo instrument, as no one except SMI (that I can find) support it robotically.
Posted : February 13, 2013 7:46 am
(@mattsib79)
Yes it does have SMI installed. It goes through the boot process and when it finishes booting it goes to a screen that says ready to use SMI data collector and reads the HA angle and VA angle.
It says trying to connect to radio #2
unable to connect....retry...press escape to exit
Matt
Posted : February 13, 2013 9:05 am
From my manual
S20 Robotic direct connect uses HP48GX 9600 baud
S20R Robotic S20 Radio requires HP48GX turbo 19200 baud (marked with orange label on front)
Posted : February 13, 2013 9:25 am
(@survey-or)
Matt,
The radio needs to be turned on before the instrument is in order to connect.
Does the email link in your profile work?
Glenn
Posted : February 13, 2013 10:28 am
